Author Topic: OPTIMA BATTERY & BILLET BATTERY CLAMP  (Read 3311 times)
February 19, 2010, 09:05:59 am
GEE-BEE
  • 1604
« on: February 19, 2010, 09:05:59 am »
I needed one , best price I found was thru FBIRIDES.COM
159.95 for Battery
59.95 for Battery Billet Clamp
I removed the spot weld's from the stock battery bracket( drilled ) and installed the battery clamp that had four bolt's included, I moved it back two inches .
Centered the new and took my old cables to a welding supply to make up new , I went with a side post mount (rear ) & top ( DUAL POST Model )
1/0 GAUGE CABLE 24' Long ,TOP BATTERY POST TO STARTER
SIDE POST FOR ACCS.
Gee-Bee
« Last Edit: February 26, 2010, 10:24:45 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
