Author Topic: Who knows something about aircooled vdubs?  (Read 6386 times)
February 09, 2010, 05:12:22 pm
« on: February 09, 2010, 05:12:22 pm »
I'm rebuilding a 1600L for a squareback, I took it apart waaaay back in '01 and have been accumulating new parts slowly.
I bought 2 brand new heads a few years ago, they came with valves and springs. Strangely one of the valves was missing the little clips so was the spring was loose in the box.
In putting it together I started wondering if there's supposed to be a lower valve seat or if the spring rides directly on the aluminum?
I found in my old parts 8 "washers" , on them they say "this side up 105 V.S.I." They fit perfectly under the spring, but I checked under another spring in the new head and it doesn't have a washer.
I have a high lift cam so I'll be replacing the valve springs with heavy duty springs and I wonder, do I need these shims to keep the springs from machining the head?
Reply #1February 09, 2010, 05:18:47 pm
truckinwagen
  • 1895
Re: Who knows something about aircooled vdubs?
« Reply #1 on: February 09, 2010, 05:18:47 pm »
definitely need a shim between the spring and head or you will have lots of issues with them machining themselves into the aluminum.
83 Opel Kadett Diesel
Reply #2February 09, 2010, 05:48:29 pm
Syncroincity
  • 727
« Reply #2 on: February 09, 2010, 05:48:29 pm »
VW Factory Microfiche: Item 22
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #3February 09, 2010, 06:43:35 pm
« Reply #3 on: February 09, 2010, 06:43:35 pm »
Thanks that's what I needed to know ;D. Seems strange that the new head didn't have anything under the springs though......silly mexicans :)
Reply #4February 09, 2010, 07:08:19 pm
« Reply #4 on: February 09, 2010, 07:08:19 pm »
Ya know, on further studying item 22 looks like the goofy valve seal/o-ring. It also looks smaller than the spring diameter. :-\
Reply #5February 09, 2010, 10:24:07 pm
Syncroincity
  • 727
« Reply #5 on: February 09, 2010, 10:24:07 pm »
Yeah, you're right.. ???
It's been so long since I've been into one of those heads, I can't remember. But it couldn't hurt, especially with HD springs or ratio rockers.
JC McCavitt
'98 Jetta Wolfie
Reply #6February 10, 2010, 12:27:07 am
« Reply #6 on: February 10, 2010, 12:27:07 am »
The 8 washers I have are .060"-.063" in thickness, I don't know if they're called shims or what. Seems like the thinner the better since the springs are so tough already.
Reply #7February 10, 2010, 04:36:33 pm
  • 1739
« Reply #7 on: February 10, 2010, 04:36:33 pm »
 2 very important things to address when building any higher perf motor, but especially an air-cooled VW. Make sure you get the valve/rocker geometry right. Check in The Samba forums about that, but be prepared to spend hours reading so you understand exactly what is involved. And next, get the right oil to break it in, plus use some additives because if not, even with the best quality lifters available, there is a good chance of making the cam and or lifters go flat within minutes of your first start-up. Oh and don't use synthetic before it's well broken in.
Reply #8February 10, 2010, 06:11:02 pm
FineFrank
  • 72
« Reply #8 on: February 10, 2010, 06:11:02 pm »
A good, if grumpy, source for air cooled dubs is geneberg.com.
Bought one of his saab forged cranks years ago and it's still running great. Even if you don't buy anything, the site is a wealth of knowledge.
Frank Longtine
1983 Rabbit Diesel 4 dr/ 1.6NA
1997 Rokon Trailbreaker
1984 Ford F-150/ 300-6
"The welfare of humanity is always the alibi of tyrants"   -Albert Camus-
Reply #9February 10, 2010, 06:38:09 pm
Turbinepowered
  • 1206
« Reply #9 on: February 10, 2010, 06:38:09 pm »
Shoptalkforums.com is another good set of forums to trawl.
Reply #10February 11, 2010, 12:51:09 pm
« Reply #10 on: February 11, 2010, 12:51:09 pm »
This isn't a reeeaaal high perf build, it's got 1650cc cylinders/pistons, jcwhitney sells some high perf cams and I can't remember if I got the "good to 5500rpm" or the 6000rpm cam. I guess that would be why I'd need to get the rocker geometry right.........
I have the Tom Wilson "How to rebuild your vw aircooled engine" book and it doesn't say anything about what oil to use though it does say how to break it in.
Reply #11February 11, 2010, 05:21:39 pm
  • 1739
« Reply #11 on: February 11, 2010, 05:21:39 pm »
Back when that book was written, even the cheapest oil had enough additives to slide a battle ship on concrete. Do a bit of research, i don't know what you have available, but general though until last week was Brad Penn is the best, but Royal Purple have break in oil.
As for the rocker geometry, if you are changing anything from stock, it should be checked and set up, even a close to stock motor, esp. if you want to wind it past 5000
