Author Topic: Advancing Pump Timing - quick n dirty?  (Read 6879 times)
January 31, 2010, 04:16:34 am
rs899
  • 647
« on: January 31, 2010, 04:16:34 am »
OK- I have the formerly trashed 91 Jetta running reasonably well now, but I am sure the IP timing is retarded because it runs sluglike compared to my Caddy and when I pull the cold start it picks right up and sounds nice.
So, I tried to advance it, but the IP has run out of room towards the block.
I need to advance the pump by one tooth, then go from there.  I think this means  holding the belt in its current position, then rotating the pump clockwise one tooth, correct?
How do you guys do such a thing without upsetting cam and crank timing?
Rick
Reply #1January 31, 2010, 06:31:52 am
Re: Advancing Pump Timing - quick n dirty?
« Reply #1 on: January 31, 2010, 06:31:52 am »
I don't believe that you can. Best would be to retime with the dial indicator. Unless someone else knows better.
Reply #2January 31, 2010, 09:04:10 am
« Reply #2 on: January 31, 2010, 09:04:10 am »
i would advise AGAINST doing what you said. if you do one whole tooth, you probably wont be able to retard it enough to run right.
Reply #3January 31, 2010, 03:33:48 pm
rs899
  • 647
« Reply #3 on: January 31, 2010, 03:33:48 pm »
Ok, technique aside, for the time being.  There has to be a way for this thing to run with the "proper" advance.  I used a dial indicator on it and it's right around 1mm right now, but it obviously needs more advance.  Maybe I didn't read it right ?( I have done it countless times, but never on this car).
What's wrong with advancing a tooth and then pulling the pump towards me?
Reply #4January 31, 2010, 04:16:02 pm
dennis
  • 311
« Reply #4 on: January 31, 2010, 04:16:02 pm »
Might want to check internal pump pressure.
1980 Caddy TD (Always in progress)
1983 Volvo 245 D24 NA Building D24T
1980 Air-cooled Westy
1956 F100 (What to do???))
Reply #5February 01, 2010, 10:14:24 am
rs899
  • 647
« Reply #5 on: February 01, 2010, 10:14:24 am »
Thanks Andrew-
In fooling around for 16 years with my Caddy, I never have had to deviate from using the dial indicator reading as gospel.  But this time with this Jetta, I am going to have to do more of a seat of the pants setting to get it running better.
I am a little nervous doing it this way, but am I correct in thinking that as long as my cam and crank are dead on with each other, having timing a tooth off one way or the other (until I dial it in by feel) will not damage anything?
Rick
« Last Edit: February 01, 2010, 12:07:35 pm by rs899 »
Reply #6February 01, 2010, 11:02:48 am
rs899
  • 647
« Reply #6 on: February 01, 2010, 11:02:48 am »
OK, so thinking ahead, if I fudge it this way and get it to run better, I presume I will end up with more lift than the book says I should have, but what?
That complicates my future timing belt changes ( if I use the same IP).  I guess I will need to eventually record what the dial indicator "sweet spot" reading is for this pump. Any better ideas?
Rick
Reply #7February 01, 2010, 11:53:03 am
« Reply #7 on: February 01, 2010, 11:53:03 am »
I think that's a very reasonable approach.  The dial indicator method doesn't account for cam wear, injector pressures etc,  so sometimes needs a bit of tweaking... but its advantage is that it's reproducable.  If you manually find where your engine runs best and then measure it you'll have dialed in your specific pump/injectors/etc in a reproducible way.
Reply #8February 02, 2010, 04:14:21 am
rs899
  • 647
« Reply #8 on: February 02, 2010, 04:14:21 am »
It occurs to me that I just need to remember to record the lift with the dial indicator on the old belt when I go to change it 3-4 years from now.  Now, the problem is trying to figure a fail-safe way to do that- perhaps a yellow sticky in the Bentley?  Except that having done this so often, I may not even look at the Bentley....getting old sucks. :'(
Rick
Reply #9February 03, 2010, 07:52:20 am
« Reply #9 on: February 03, 2010, 07:52:20 am »
write it on the wall of your shop. thats where i write stuff that i dont wanna lose.
Reply #10February 03, 2010, 08:09:10 pm
« Reply #10 on: February 03, 2010, 08:09:10 pm »
I keep a notebook in my tool box ;) I'm only 20.. but i still have a memory like sieve sometimes lol
Reply #11February 04, 2010, 03:50:35 am
rs899
  • 647
« Reply #11 on: February 04, 2010, 03:50:35 am »
Maybe I'll put a note on the strut tower.  If I use a permanent marker, though, it might eventually fade due to diesel and solvents- probably have to use paint.
Reply #12February 07, 2010, 06:50:35 am
ein bora
  • 377
« Reply #12 on: February 07, 2010, 06:50:35 am »
The flywheel on my 1.9 IDI has two TDC marks, apparently the same flywheel is used on some gassers so the second mark is 6 degrees BTDC. When I first set the timing up of coarse I had the wrong TDC. The car ran but I had to run the pump all the way up to advance it as far as I could - and had issues like you described. When I finally figured it out, now it sits where it should and runs as it should. Not saying you have the same issue, but maybe worth checking out.
If you can't take advice - then you can't be helped!
Reply #13February 07, 2010, 03:04:28 pm
rs899
  • 647
« Reply #13 on: February 07, 2010, 03:04:28 pm »
I think my flywheel is OK, since I had the head off a few weeks ago and it looked like TDC was where I expected it (but I know the gasser flywheel you are talking about and I agree it is confusing).  I slipped the IP one cog advanced and now it runs better- and I used up almost that whole cog.  I haven't measured it with a dial indicator- I am curious to find out what it is.
Reply #14February 07, 2010, 07:19:16 pm
« Reply #14 on: February 07, 2010, 07:19:16 pm »
i had that problem too, as i used a gasser flywheel, and it had only gasser timing marks.
