Author Topic: Dynolicious iPhone App  (Read 8034 times)
January 28, 2010, 11:51:10 am
blackdogvan
  • 574
« on: January 28, 2010, 11:51:10 am »
Any iPhones near you??
I've been playing with the Dynolicious App, it was bang on with a friends E46 M3 5sec 0-60 time & with a 4300lb vehicle weight & 19% driveline loss my rover pin AAZ showed 82hp. Repeated pulls were all identical. Regardless of the hp number with that repeatability any changes can be easily tested against that baseline. Of course without a RPM number calculating torque is out unfortunatly but for gauging the effectivness of this or that tweak, IC change, injector change etc it's fantastic.
FYI on the run here it wasn't a proper 0-60 run, I short shifted 1st in traffic & then accellerated hard in 2nd & 3rd with slow shifts. Its all about the accelleration over time for the hp calc so thats all I was going for. (no flame action on the 15.7@47mph 1/8 mile ok?) I think with a 2nd gear from idle to 4500rpm pull the curve would be pretty accurate.
With the same app being used & the same driveline loss as long as the vehicle weights are is accurate we can actually start to compare performance numbers around the world.
Any takers??
1991 Vanagon 1.9 mTDI
Reply #1January 28, 2010, 02:54:19 pm
jack's lack
  • 275
Re: Dynolicious iPhone App
« Reply #1 on: January 28, 2010, 02:54:19 pm »
I think I'll get it. As long as you get a baseline it would be good for tuning. This way I can confirm that installing an intercooler and a boost controller are actually helping.
1982 Rabbit diesel L 4 door
AAZ, K14, Giles pump, PD150 intake, P&P'd head, ceramic coated pistons, 2.5" stainless down pipe & exhaust. FK coils
My Build Thread
Reply #2January 28, 2010, 05:44:54 pm
rallydiesel
  • 1880
« Reply #2 on: January 28, 2010, 05:44:54 pm »
That's cool. A little bit more accurate than a butt dyno I guess.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #3January 28, 2010, 08:07:41 pm
foxracer1
  • 991
« Reply #3 on: January 28, 2010, 08:07:41 pm »
awesome now i want an iphone!
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #4January 28, 2010, 10:36:43 pm
  • 3468
    • McScrubbins Body Wash
« Reply #4 on: January 28, 2010, 10:36:43 pm »
me too!!
I didn't need a thing other than my butt dyno to tell me my IC made a difference!!!!
Reply #5February 24, 2010, 02:17:58 am
maxfax
  • 2126
« Reply #5 on: February 24, 2010, 02:17:58 am »
I ended up buying one of the iPod touches after reading about this... I wanted an mp3player anyhow, why not go all out! So, when will the vwdiesel.net app be ready??
P.S. I'm sending this post from the aforementioned iPod.. Nothing like being able to keep up on forums from the toilet! ;D
Reply #6February 24, 2010, 02:37:10 am
DCC
  • 184
« Reply #6 on: February 24, 2010, 02:37:10 am »
I bought this a couple years ago. Oldie but goldie:
http://www.amazon.com/Beltronics-FX-2-Vector-FX2-VPC/dp/B000246URG
It's pretty precise when you enter all the data (weight, aerodynamics, pitch, yaw). I tested it with my car and others, and the numbers were quite right.
Reply #7February 25, 2010, 12:41:57 am
anto
« Reply #7 on: February 25, 2010, 12:41:57 am »
Tried this on my gf's iphone and it seems my 1.9 turbo diesel peugeot 306 has 260bhp, SWEEEEEEEET!
I knew it had a bit more than 90bhp  but not that much haha.
Think i might need to adjust the weight i entered in it for the car.
Reply #8February 25, 2010, 07:57:19 am
« Reply #8 on: February 25, 2010, 07:57:19 am »
Needs to work for Android platform also..
Reply #9February 25, 2010, 12:22:45 pm
blackdogvan
  • 574
« Reply #9 on: February 25, 2010, 12:22:45 pm »
What did you use for driveline loss??
Reply #10February 26, 2010, 03:50:47 am
maxfax
  • 2126
« Reply #10 on: February 26, 2010, 03:50:47 am »
My V8 station wagon made 98 hp at the back wheels..   ;D ;D ;D ;D
Reply #11February 26, 2010, 07:32:17 am
blackdogvan
  • 574
« Reply #11 on: February 26, 2010, 07:32:17 am »
The thing I like about it is no matter what you use for weight & driveline losses, if you keep those parameters you can very closly monitor the effects of tweaks or mods for actual differences instead of the old butt dyno method.
Reply #12February 26, 2010, 10:34:38 pm
maxfax
  • 2126
« Reply #12 on: February 26, 2010, 10:34:38 pm »
I feel that it is still fairly accurate..   The wagon I mentioned earlier is only rated at 170hp...  I used the advertised curb weight plus my weight..  Didn't take into consideration the extra weight of the tool boxes and a full tank of gas...  With driveline losses, and wind resistance a 70hp loss to the back wheels doesn't seem too far off..  When the snow goes away I need to do another run with all the crap removed and an empty tank...
Reply #13March 01, 2010, 03:58:30 am
anto
« Reply #13 on: March 01, 2010, 03:58:30 am »
19 or 20% i think similar to what you used, both being fwd cars after all.
Please note i do not think my car has 260bhp lol
