Author Topic: 1.9 AAZ Turbo and Non Turbo Coolant hardline ( Pump to Firewall )  (Read 2060 times)
January 24, 2010, 02:57:34 pm
GEE-BEE
  • 1604
I bought two different Coolant hardlines pump to firewall heater hose  (AAZ & TDI )from the VWdiesel website for my AAZ 1.9TD
The TDI and the AAZ are interchangeable, the TDI pipe does have a extra mounting tab on the rear
The aaz line from them does have the vw part # on it and Iam not sure if it is old stock ?
I bought both for 20.00 and the aaz model is around 9.00
I did see some rust under the paint of the new assy,so iam going to bead blast and check for additional corrosion and then powder coat when finished.
I was told that a New was about 87.00 from VW , and iam also trying to find the plastic clip part #'s that attach to the hardline to hold the engine wiring harness ?
I need five clips since there not included on the coolant pipe from the dealer or the vwdiesel wesite.
I have  purchased some convoluted black slitted tubing for my wires in my engine compartment so I can use the clips to hold my wire loom.( oil psi & oil temp ) gauges .
I would recommend this item only from this website.
Gee-Bee
« Last Edit: January 24, 2010, 08:02:39 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1January 24, 2010, 06:08:13 pm
Henchman
  • 183
Re: 1.9 AAZ Turbo and Non Turbo Coolant hardline ( Pump to Firewall )
« Reply #1 on: January 24, 2010, 06:08:13 pm »
GEE-BEE, I love you man, but I have no idea what you are talking about!
Coolant hard lines, got it.  I get confused for a while after that... Something about money....  Rust, bead blast, makes sense...  More money...  Plastic clip for wiring harness, I start to get lost again, beside an AAZ has like 6 wires, how much harness do you have?  Something about tubing...  Recommendation of a website, which one?
I need a drink,
Ian
Reply #2January 24, 2010, 06:32:17 pm
starrd
  • 128
« Reply #2 on: January 24, 2010, 06:32:17 pm »
was just looking in Etka - could it be 021 971 848 A  - cable holder connecting part cooling pipe
In Etka
MG = 9, SG = 71 illustration 194-20
Black 1996 Passat TDI Malone tune, K03/04 Hybrid, Keyless, VR6 Clutch & PP357's
White 1993 Passat TD - GTD nozzles, Keyless - Giles pump, K14, Intercooler, 228mm VR6 clutch & PP, CTN Trans etc
Red 1990 Corrado - custom chip by
Reply #3January 24, 2010, 08:04:13 pm
GEE-BEE
  • 1604
« Reply #3 on: January 24, 2010, 08:04:13 pm »
Clip's , Not that part number
I will have the dealer bring in six different model's ( part #' )
Thanx GB
« Last Edit: January 26, 2010, 03:00:11 pm by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
