Author Topic: aaz ahu combo  (Read 5438 times)
January 23, 2010, 06:15:30 am
elbandito
  • 5
aaz ahu combo
« on: January 23, 2010, 06:15:30 am »
i have an mk3 golf with an aaz i'm planning to put in my mk1 caddy, i also have access to an ahu engine, was wondering what combination i could use from them both to make a fairly quick engine? any help would be appreciated
Reply #1January 23, 2010, 07:24:09 am
Re: aaz ahu combo
« Reply #1 on: January 23, 2010, 07:24:09 am »
its still gonna be either an IDI or TDI engine. and they arent really enough different that you can make power just by swapping parts. they are basically the same engine, just one is direct injected, and one is indirect injected. almost the same bottom end tho.
Reply #2January 26, 2010, 12:19:11 pm
elbandito
  • 5
Re: aaz ahu combo
« Reply #2 on: January 26, 2010, 12:19:11 pm »
cheers mate, i'm not really that clued up on diesels, would using the ahu turbo inlet and intercooler make much difference, or would i be better using 1.6td pump etc? not working on a huge budget
Reply #3January 26, 2010, 03:34:09 pm
jack's lack
  • 275
Re: aaz ahu combo
« Reply #3 on: January 26, 2010, 03:34:09 pm »
The AHU has the D-shaped crank nose which is less prone to failure than the AAZ keyway nose. So which ever route you go you should use the AHU crank and pulley.
I used a 1Z crank in my AAZ for this reason.
Are you planning on running an ECM? the wiring could get complicated. I would go MTDI, or run the AAZ. The AAZ is a pretty straightforward swap into the MKI and it rips.
Does anyone know if an AHU will bolt to an 020. I Bentley says they came on the 1Z. If you have to swap to a cable shift that could be a chore.
1982 Rabbit diesel L 4 door
AAZ, K14, Giles pump, PD150 intake, P&P'd head, ceramic coated pistons, 2.5" stainless down pipe & exhaust. FK coils
My Build Thread
Reply #4January 29, 2010, 10:32:00 am
elbandito
  • 5
Re: aaz ahu combo
« Reply #4 on: January 29, 2010, 10:32:00 am »
cheers buddy, think i'll go wi using the ahu crank and pulley, no sure how m-tdi works? maybe just use 1.6td pump and intercooler
Reply #5January 29, 2010, 12:59:14 pm
Re: aaz ahu combo
« Reply #5 on: January 29, 2010, 12:59:14 pm »
its not just slap-some-parts-together-and-run affair, its much more in depth than that. if you dont know the differnece between a IDI and TDI, you should probably not try building one.
Reply #6January 29, 2010, 01:22:07 pm
Re: aaz ahu combo
« Reply #6 on: January 29, 2010, 01:22:07 pm »
No need to be a Sour Puss Kev, why not take a little extra initiative and link them to some useful information instead of telling him he is stupid for trying?
Here you go Elbandito, I suggest you read up on this.
http://www.vwdiesel.net/forum/index.php?topic=20109.0
They are two different engine, the AAZ and the AHU. If you have access to complete engines of both.. and you have all the wiring needed for the AHU by all means you will get more power with that route.. The AHU is a Direct Injection motor, which is completely different from the AAZ which is an Indirect Injection motor.. Both will be very torquey and ballsy in an mk1 chassis. It's up to you on how you want to do this.. Mechanical (AAZ) or Electronic (AHU) ;)
AAZ will be at least a little bit easier, as there is no wiring involved.. no computer to worry about. Swap some motor mounts, hook up some coolant hoses, few electrical connections and your pretty much rollin'.
What do you want from the Caddy when you are done it?
« Last Edit: January 29, 2010, 07:34:46 pm by 8v-of-fury »
Reply #7January 29, 2010, 06:42:54 pm
Re: aaz ahu combo
« Reply #7 on: January 29, 2010, 06:42:54 pm »
and i dont think you can bolt an AHU crank in a AAZ block. if it has a reluctor ring, it wont fit.
Reply #8January 29, 2010, 08:12:27 pm
rallydiesel
  • 1880
Re: aaz ahu combo
« Reply #8 on: January 29, 2010, 08:12:27 pm »
I'm pretty sure an AHU crank will fit an AAZ block. The AAZ and AHU blocks are basically interchangeable. For that reason, a 020 trans should bolt to the AHU trans with no issue, aside from swapping between cable/rod shift and hydro/cable clutches  :-[.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #9January 30, 2010, 08:46:00 am
Re: aaz ahu combo
« Reply #9 on: January 30, 2010, 08:46:00 am »
ok, well theres some sort of TDi's that have reluctor rings and oil pump drive sprockets on them. i know those are a little harder to get to fit in an aaz. thats what i was thinking is all.
Reply #10January 30, 2010, 08:50:51 am
Re: aaz ahu combo
« Reply #10 on: January 30, 2010, 08:50:51 am »
ALH is the engine model after the 1Z/AHU TDIs.  With that change there isn't much that will interchange.  The 1Z/AHU bottom end is pretty much interchangeable with the AAZ aside from the pistons.
yes, thats what i was thinking. im just not as clued in with the TDI's as i am with the idi's. knew there was a difference, just wasnt sure what engines.
Reply #11January 30, 2010, 10:01:24 am
elbandito
  • 5
Re: aaz ahu combo
« Reply #11 on: January 30, 2010, 10:01:24 am »
thats helped loads thanks, i'll tell my mate to keep his ahu and stick with the easyier option and put the aaz in, again thanks for your help
Reply #12January 30, 2010, 10:30:19 am
Re: aaz ahu combo
« Reply #12 on: January 30, 2010, 10:30:19 am »
do the TDi crank nose conversion on the AAZ and build the PISS out of it.
