Author Topic: Clutch and transmission issues  (Read 6383 times)
January 22, 2010, 05:01:51 am
jack's lack
  • 275
« on: January 22, 2010, 05:01:51 am »
Alright, so now that I have the AAZ in and running, it is clear that my current setup is not going to work. When I get above 10psi my clutch just starts slipping.
It is a Sachs stage1 with less than 5,000 miles on it used in conjunction with a 16v pressure plate and a 9lb flywheel. (210mm)
I can find some performance kits online as upgrades sold as stage 2, 3 & 4. They are described by how much HP they can handle presumably from a gasser.
It seems like torque would be a far more useful value in this case. What kind of numbers would an AAZ with my setup be making roughly anyway? (I am shooting for 20psi)
I think I need to go up to a 6 puck with a sprung center and the next step up for the pressure plate. Will this hold?
Should I step it up from organic to a cerametalic? or to sintered?
The other thing I am thinking is that if I am going to spend nearly $500 on a new clutch setup, maybe I should think about swapping trannys. I don't think my 5th is tall enough for the freeway.
I will see if I can find the number on my 020 so at least we will know what I am working with.
Just as a lark, what is involved in going up to a 6spd box in a MK1?
Those of you that are happy with your setups let me know what you are running, where you got it and how much you paid.
Cheers,
Ryan
1982 Rabbit diesel L 4 door
AAZ, K14, Giles pump, PD150 intake, P&P'd head, ceramic coated pistons, 2.5" stainless down pipe & exhaust. FK coils
My Build Thread
Reply #1January 22, 2010, 05:24:43 am
dennis
  • 311
Re: Clutch and transmission issues
« Reply #1 on: January 22, 2010, 05:24:43 am »
I use to run a Clutchnet three puck disc with a stock pressure plate on an 83 GTI 1.8 (Built) plus a 100hp shot of nitrous. It held but axles, but stock 9A, and 4K transmissions did not. Killed the diff rivots in both cases. Finally got a Quaif Diff which held, but didn't stop the axles from snapping. I am pretty new to performance diesels but it sounds like you will need to keep moving the money around the car untill everything is strong enough to hold. Sounds like I need an AAZ. My stock 1.6 gets to 10psi my stock clutch holds fine.
1980 Caddy TD (Always in progress)
1983 Volvo 245 D24 NA Building D24T
1980 Air-cooled Westy
1956 F100 (What to do???))
Reply #2January 22, 2010, 05:27:38 am
GEE-BEE
  • 1604
« Reply #2 on: January 22, 2010, 05:27:38 am »
here you go Ebay 290386672942
You will have to put 100 mm inners on like I did
P.S. your hose shipped via mail
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #3January 22, 2010, 06:52:02 am
jack's lack
  • 275
« Reply #3 on: January 22, 2010, 06:52:02 am »
Okay Trans code is FN (January 29, 1982 is the date on it)
which means I have a .71 5th gear and a final drive of 3.89. So it is actually one of the better ones
Gee Bee man what do you do hang out on the internet all day searching for all the good stuff?
That transmission CHD has a .75 5th gear and a final drive of 3.67
So at 80mph they are essentially the same only a few RPM better for the CHD
FN is on the left CHD is on the right
My question is, can I put a 3.67 final drive (Ring and Pinion) in my transmission, or modify a CHD to have a .71 5th gear ?
FN on left, FN with 3.67 R&P is on the right
What is involved in doing this?
in either of the latter scenarios at 70 to 80mph we are looking at a drop of about 200RPM which I think would be a step in the right direction
« Last Edit: January 22, 2010, 06:53:56 am by jack's lack »
My Build Thread
Reply #4January 22, 2010, 07:04:27 am
GEE-BEE
  • 1604
« Reply #4 on: January 22, 2010, 07:04:27 am »
I was first thinking of a FF code, then I found this later style trans and installed a Peloquin
P.S. Yes I pretty much sit in a comfy chair selling aircraft seals most of the day!
I'am just two blocks from the beach and four blocks from the Pier here in So cal
I paid 450.00 for a complete overhaul plus new transaxles and the PQ diff.
I told Giles to set my pump for 17psi, I traded him a new T3 for the overhaul.
I wanted a bulletproof  trans since I knew of the upgrades later.
If you need me to ship that trans, I know if we ship Fed Ex ground it will save you some money, sell yours for 150.00..
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #5January 22, 2010, 07:11:59 am
jack's lack
  • 275
« Reply #5 on: January 22, 2010, 07:11:59 am »
GB, that sounds very nice, I am a little jealous.
How the hell did you get a PQ differential and an overhaul for $450? I have seen the Peloquin LSD for over $700 alone.
I'm thinking if I go frankenstein on a transmission, I might as well upgrade to a LSD too.
do these projects ever end?
btw thanks for the hook up on that hose, I will let you know when it arrives.
My Build Thread
Reply #6January 22, 2010, 07:28:44 am
GEE-BEE
  • 1604
« Reply #6 on: January 22, 2010, 07:28:44 am »
That was the price for just the OHC, I found a new in the box PQ O20 ( bad listing ) on ebay for under 350.00
Sometime sellers dont list there item on ebay correctly, it's all about how you search,The new T3 cost me less than 325.00.
The T3 was worth 1165.00, So the Giles pump OHC was a deal !
I used to broker aircraft parts when I was twenty, I have been in the aviation field since 79
I designed a seal for aircraft mfg ( Battery Box ) that paid for 2008 997TT
My son and I have done three caddy restorations, the last Lt blue one is owned by a TDI Jetta Cup driver.
It has been shown often on the Vw vortex....
Stay Tuned and dont touch that Dial !
GB
Here to help other people and I blessed that my aircraft customers pay for everything...
« Last Edit: January 22, 2010, 07:49:46 am by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
Reply #7January 22, 2010, 10:32:06 am
91redjetta
« Reply #7 on: January 22, 2010, 10:32:06 am »
where can i find that trans calculator?
i'm running and acn in my rabbit truck with a 1.6t pushing 22psi through a k24 and intercooler.. i run a stock disc with a gli pressure plate. 210mm and have no slipping problems.. only when i put my feet on all three petals to lit the turbo and spin the tires.. ha!! its done that a few times though.. and it would boost creep to 25 psi in fourth.. still no slip.. i think your flywheel needed surfaced or something..
and if you don't believe me ask foxracer1 on here... he'll tell you.. he was killing clutch disc but thats because he likes to johnny hot step the clutch..
Reply #8January 22, 2010, 10:40:36 am
« Reply #8 on: January 22, 2010, 10:40:36 am »
#1 murder of clutches for sure. i found out that when i quit dumpin the clutch, it worked alot better daily driving. its kinda cool watchin your boost gauge go from damn near zero, to 25-30 psi pretty much instantly when you let the clutch fly.
my setup is a 16v plate, gas 8v wheel, and 210mm 8v sachs clutch.
Reply #9January 22, 2010, 10:53:44 am
91redjetta
« Reply #9 on: January 22, 2010, 10:53:44 am »
ya sounding like an old man when i say this but its hard on stuff just steeping off thats fo sure.. i'm a load and leave kind of guy.. ha
Reply #10January 22, 2010, 11:09:19 am
« Reply #10 on: January 22, 2010, 11:09:19 am »
the only time i am really hard on my clutch is when im burning out.
yes, i know burn outs are hard on your transmission, axles, clutch, and motor mounts, but god damn, i just love fryin the tires off. i used to get maybe a full rotation from the tires when it was n/a, now it just blows the tires off. 2nd gear rubber is no problem.
120ft 2nd gear posi burn outs rock! (lol)
Reply #11January 22, 2010, 04:35:30 pm
91redjetta
« Reply #11 on: January 22, 2010, 04:35:30 pm »
trans calculator!??????
Reply #12January 22, 2010, 06:05:31 pm
jack's lack
  • 275
« Reply #12 on: January 22, 2010, 06:05:31 pm »
hey patience here you go. I just googled transmission calculator and this came up.
http://www.fatboyraceworks.com/gears/index.php
Well whether or not I should be having a problem I am. I am not talking about when I am touching the clutch pedal either. The slip occurs when I am cruising along in a gear and I floor it. i.e. doing 55 in 5th and stomp it the clutch slips for awhile before it will grab and I actually start accelerating. Maybe I got some coolant or oil on the damn thing during install. if the 16v pressure plate is strong enough, maybe I can get away with just stepping it up to a 6 puck ceramic clutch. The flywheel and the pressure plate were replaced with the clutch less than 5,000 miles ago and have almost all of those miles with a wimpy 1.6 NA on a giles pump. so I think the surfaces are fine.
« Last Edit: January 22, 2010, 06:15:37 pm by jack's lack »
My Build Thread
Reply #13January 23, 2010, 03:07:57 am
MouseGTD
  • 110
« Reply #13 on: January 23, 2010, 03:07:57 am »
are these uprated parts or just standard replacement parts? is the 8v gas flywheel much different to the diesel one?
Reply #14January 23, 2010, 07:29:45 am
« Reply #14 on: January 23, 2010, 07:29:45 am »
its bigger than the 200mm clutch that comes on them factory. grabs alot better too. little harder clutch pedal resistance tho. and the flywheel is about 5 pounds lighter than the diesel flywheel. but it doesnt have diesel timing marks, so you just gotta know where to put the mark.
