Author Topic: Custom cams, Volunteers needed  (Read 16581 times)
Reply #30November 16, 2005, 01:18:04 pm
therabbittree
  • 299
« Reply #30 on: November 16, 2005, 01:18:04 pm »
jake..yup 2.5mm or so valve relief on the pistons.. you've seen simon's old posts on the tdi club forum right?..about his cams and mech tdoi a2 golf?..remeber his old 1.6LTD in a mk1 golf in the golf magazine about 5 yrs plus ago.. he used a g grind in that one too...any how his site http://www.centralvwaudi.com/ has pics and such regarding his tdi and cams etc..
thanks off to mess with the pickup..in the rain yuck...
later
Deo
\x/ hillfolk!
Reply #31November 16, 2005, 05:37:22 pm
935racer
« Reply #31 on: November 16, 2005, 05:37:22 pm »
These cams require no modifications. Hopefully will have some Gtechs up tonight.
Reply #32November 18, 2005, 04:54:53 am
therabbittree
  • 299
« Reply #32 on: November 18, 2005, 04:54:53 am »
just to clear it up i didn't mean dave's cam needed clearancing ..i meant the g grind cam adapted to a diesel needs clearancing..... i hope to buy one of you cams soon..can you pm me some info..ie  address tosend the core diesel cam etc
thanks
deo
Reply #33November 18, 2005, 05:58:38 am
2383 GTD
« Reply #33 on: November 18, 2005, 05:58:38 am »
Dave,
Are you making custom cams for those 6 cylinders as well  8)   Also, is the base circle changed, or is it maintained?
Reply #34November 18, 2005, 09:02:07 am
  • 1156
    • Malone Tuning Ltd.
« Reply #34 on: November 18, 2005, 09:02:07 am »
I haven't seen 935racer do 6cyl cams yet but it definitely can be done. The cam shop he's dealing with specializes in diesels and does many Cummins, Powerstrokes, etc. cams.
If you send 935racer a cam I'm 90% sure he'll get it done for you (with no core charge of course, because you'd have already sent him a cam). Is it from a Volvo 2.4?
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #35November 18, 2005, 10:26:12 am
935racer
« Reply #35 on: November 18, 2005, 10:26:12 am »
Yes we can do 6 cyl versions as well but i have no cores so you will need to send me one they will cost slightly more due to haveing more lobes. Yes the base circle does change, not it does not have any adverse affects. There is plenty of preload on the lifters to ensure constant contact betweent he cam lobe and lifter.
Reply #36December 13, 2005, 03:58:09 am
2383 GTD
« Reply #36 on: December 13, 2005, 03:58:09 am »
No problem, send me a PM about this.  I have several spare cams, so I can easily send one.  Thanks Dave  8)
Quote from: "935racer"
Reply #37December 14, 2005, 08:40:48 pm
2mAn
« Reply #37 on: December 14, 2005, 08:40:48 pm »
im sure its probably pointless, but have u considered making a non-turbo diesel cam.... ive got a modified pump from giles on the way and im curious to see if i can get to 100bhp with a 1.6. the pump alone should get me to around 75bhp. im sure it will require headwork in addition to a better breathing intake and exhaust setup, but id still like to try it
Reply #38December 15, 2005, 10:20:01 am
Northern RD
  • 167
« Reply #38 on: December 15, 2005, 10:20:01 am »
Quote from: "2manVR6"
You can count me in for an N/A cam as well!!
N.
P.S.
Merry Xmas all!
Reply #39December 15, 2005, 10:56:19 am
  • 1156
« Reply #39 on: December 15, 2005, 10:56:19 am »
Chalk me up for a N/A cam regrind as well :) for a future project..
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #40December 15, 2005, 02:27:02 pm
935racer
« Reply #40 on: December 15, 2005, 02:27:02 pm »
hmmmm, I would like to try one of my custom cams in a NA diesel. Just so you know, all cams will be HYD lifter only, there isn't enough demand to make it worth my while to do a solid lifter version.
Reply #41December 15, 2005, 02:46:04 pm
DVST8R
  • 535
« Reply #41 on: December 15, 2005, 02:46:04 pm »
Dave I think that the NA would be a good candidate for the "BIG" cam like the race cummins profile.... :twisted:
The Brett of the board...
The Dark Side of Beauty.[/i]
Reply #42December 15, 2005, 05:39:09 pm
935racer
« Reply #42 on: December 15, 2005, 05:39:09 pm »
Brett I think you are right on there, the big race cam would probably work great in the NA diesel. Hey I sent you a PM buddy, check it!
Reply #43December 15, 2005, 06:03:23 pm
VWRacer
  • 649
« Reply #43 on: December 15, 2005, 06:03:23 pm »
...all cams will be HYD lifter only...
I must have missed this, Dave. Does that mean there's nothing for those of us with solid lifter 1.6TDs?
Stan
C-Sports Racer
Reply #44December 15, 2005, 06:24:18 pm
935racer
« Reply #44 on: December 15, 2005, 06:24:18 pm »
Well I should check the specs on the solid lifter TD ones before I say no, you likely could if you adjusted your shims accordingly. I'll get back to you guys about that.
Volvo cams, I am gonna get some prices on that. Definately doable, I would say around the $300-320 range you provide the core.
Chistmas specials on the regular TD cams guys. stage 2 is now $220USD with your old core. Your old core can be from a solid lifter or hydro and either NA or turbo. It just has to be in good condition, Don't send anything that is not something you wouldn't throw into your car and run.
