Author Topic: How often is a bad IP rotor the culprit of smoke?  (Read 1906 times)
January 19, 2010, 12:52:38 pm
overdrivegear
  • 120
« on: January 19, 2010, 12:52:38 pm »
I was wanting to know how often would a bad IP hydraulic head and rotor be the culprit of black smoke in a 1.6 NA?
Facts:
glow plugs: 7 sec.
timing: 1.0mm
T-stat: 192 F
Injectors: 155 bar, re-manufactured Bosch
Head gasket: composite with ARP studs @ 85 ft. lbs.
Maybe the pump need some fuel injector cleaner run through it or something.  I just can't think of anything else that could cause any soot.  You can't see it all that well in the rear view mirror during the day, but at night with someone's headlights behind you, it looks like you're transporting Cheech and Chong.
1985 Westy Golf 1.6 NA
1987 Cabriolet (soon to be 1.6 NA)
Reply #1January 19, 2010, 02:58:31 pm
foxracer1
  • 991
Re: How often is a bad IP rotor the culprit of smoke?
« Reply #1 on: January 19, 2010, 02:58:31 pm »
Standard operating procedure for vw diesel most any mechanical for that matter. Headlights will make the slightest haze look worse.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
