Author Topic: TDI and IDI cam question?  (Read 3787 times)
January 19, 2010, 10:59:38 am
« on: January 19, 2010, 10:59:38 am »
is there any gains from the TDI cam? will it even work? just a thought i had...
Reply #1January 19, 2010, 02:18:25 pm
blackdogvan
  • 574
Re: TDI and IDI cam question?
« Reply #1 on: January 19, 2010, 02:18:25 pm »
Nawww, AAZ cam is a upgrade for a 1Z/AHU.
1991 Vanagon 1.9 mTDI
Reply #2January 19, 2010, 06:01:30 pm
« Reply #2 on: January 19, 2010, 06:01:30 pm »
yeah i was thinking an older cam is probably better because of the later emissions
Reply #3January 20, 2010, 01:17:53 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #3 on: January 20, 2010, 01:17:53 pm »
Well, no AAZ's at our local friendly breaker, so an early TDi cam out of a Mk3 passat it is. Unknown miles, which is a nuisance as the mileometers in these things are electronic, so who knows? Undecided. Just for the interested the lobe measurements were, Base circle 37.98mm, Best Tip to Base 46.28mm, Worst 46.12mm.
So lift would be assumed as 8.3mm. But looks as though some wear is on its way. 0.16mm, but hopefully it will make less racket than the present occupant. Wish me luck. Grin
Hmm....... Deep thought. Just measured the cam as is in the engine. This is a SB engined GTD, so should be the real deal, Base Circle same or similar to above 37.98mm No.1 cam peak I measure 46.82mm, No.2 is 45.80mm, No.3 is 46.81mm, Oh joy, clapped cam, I have found it! No.4 45.82mm WTF says I, No.5 45.82mm, depression setting in, No.6 46.80mm, No.7 45.82mm, No.8 46.82mm. So the good news is I have a fine camshaft, If I have it right, the valves go EIEIIEIE, if so then Exhaust lift is 8.84mm ish, Intake lift is 7.84mm ish. Weird, go figure. Huh
Here was the full monty. http://www.vwdiesel.net/forum/index.php?topic=21328.msg164903#msg164903
Should give you an idea of what you are up against. 8)
« Last Edit: January 20, 2010, 01:19:58 pm by smutts »
Reply #4January 20, 2010, 02:22:31 pm
blackdogvan
  • 574
« Reply #4 on: January 20, 2010, 02:22:31 pm »
Just missing one tiny important bit...
Reply #5January 20, 2010, 03:41:18 pm
ryanp
  • 269
« Reply #5 on: January 20, 2010, 03:41:18 pm »
Does it seem an AEY is an upgrade for IDI and TDI??
Brand new TDi injector sets:
http://www.vwdiesel.net/forum/index.php?topic=25862.0
Golf Mk2 TDi Van - 250WHP
Reply #6January 20, 2010, 04:31:53 pm
blackdogvan
  • 574
« Reply #6 on: January 20, 2010, 04:31:53 pm »
Anyone remember the lift numbers for the AAZ cam?
Reply #7January 20, 2010, 07:22:23 pm
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
« Reply #7 on: January 20, 2010, 07:22:23 pm »
Since we are on the cam subject, my aaz cam needs a cam gear, didn't come with one.  Is there a substitute, or do I have to use the aaz cam?
Reply #8January 21, 2010, 07:58:52 am
« Reply #8 on: January 21, 2010, 07:58:52 am »
put a 1.6 cam sprocket on it
Reply #9January 21, 2010, 02:44:05 pm
« Reply #9 on: January 21, 2010, 02:44:05 pm »
can we dig up the numbers of 1.5, n/a cams, eco cams, and 1.6td cams?  perhaps different years were different as well.  also the aey and 1y are very similar and may have the same cam
Reply #10January 21, 2010, 09:11:47 pm
NintendoKD
  • 931
    • myspace page
« Reply #10 on: January 21, 2010, 09:11:47 pm »
Wait! don't tell me that the turbo cam and the N/A cam sprocket are different, I just got one from another member. :'(
Reply #11January 22, 2010, 06:35:37 am
« Reply #11 on: January 22, 2010, 06:35:37 am »
the lift atleast, is the same on all diesel cams ive played with. my 1.5, 1.6, and 1.6td all have roughly the same lift.
Reply #12January 22, 2010, 09:52:21 am
foxracer1
  • 991
« Reply #12 on: January 22, 2010, 09:52:21 am »
The cam sproket isn't but the cam specs may be slightly. Nothing major. Physically All IDI cam interchange and i believ so do TDI cams.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
