Author Topic: 1994 golf TD parts compatibility (help)  (Read 4985 times)
January 18, 2010, 09:09:19 pm
gribur
  • 84
« on: January 18, 2010, 09:09:19 pm »
Hi guys,
I have a 94 golf TD with AAZ engine.  I need a replacement alternator and was wondering if anyone has the part number, or knows which alternators are the same in other years/makes of vw's.  Does it matter if it has A/C ?
please let me know, need an alt. fast.
cheers
Reply #1January 19, 2010, 07:32:21 am
GEE-BEE
  • 1604
Re: 1994 golf TD parts compatibility (help)
« Reply #1 on: January 19, 2010, 07:32:21 am »
I think those were at least 90 amp alt with air
I found a new unit for 65.00 on ebay, I searched under the Bosch model number
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2January 19, 2010, 08:01:45 am
catlin_cava
  • 1954
« Reply #2 on: January 19, 2010, 08:01:45 am »
Most vw 90 amp alts will mork but it neeeds to be one with ac,
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #3January 19, 2010, 08:19:42 am
jack's lack
  • 275
« Reply #3 on: January 19, 2010, 08:19:42 am »
this is the problem I had with my build. I have a non AC engine and the mount is different/ incompatible with the AC version
The no AC bracket and alternator are on the left the with AC alternator is on the right. The no AC version uses a spring under the alternator to tension the belt. The AC version uses a separate tensioner. The good news is that the with tensioner version is way more common and most VW's you find at the junkyard have this type of alternator usually in 90A or 120A versions typically they are Bosch brand. Also the wiring harness is a little different too.
1982 Rabbit diesel L 4 door
AAZ, K14, Giles pump, PD150 intake, P&P'd head, ceramic coated pistons, 2.5" stainless down pipe & exhaust. FK coils
My Build Thread
Reply #4January 19, 2010, 08:42:10 am
GEE-BEE
  • 1604
« Reply #4 on: January 19, 2010, 08:42:10 am »
Correct, I purchased a set of A/C brackets from a member and found the alt ( air type ) if I choose to install the compressor .
non a/c are 70 amp
Great Post !
GB
Giles Pump OHC
MK1 JETTA DASH
