Author Topic: Pre cup  (Read 3013 times)
November 01, 2005, 05:23:19 pm
935racer
Pre cup
« on: November 01, 2005, 05:23:19 pm »
I am working on compiling as much info as possible on the vw idi pre cup inserts. Today I bought a brand new 1.9 pre cup, and I pulled a 1.6td precup and a 1.6 na pre cup and measured the volume.
1.9td-5.8cc
1.6td-5.2cc
1.6na-5.5cc
Pictures and more measurements comming tonight. Also I am working on setting up my own ceramic coating set up. I plan on testing ceramic coated valves, pre cups and pistons, and offering these services to other diesel enthusiasts as well!
Lets talk about porting and coating these things!
Reply #1November 01, 2005, 05:51:52 pm
  • 1156
    • Malone Tuning Ltd.
Pre cup
« Reply #1 on: November 01, 2005, 05:51:52 pm »
The IDI forum is on a roll. So much diesel potential to come :twisted:
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #2November 01, 2005, 07:35:03 pm
RedRotors
  • 734
    • http://www.mikrotuning.com
Pre cup
« Reply #2 on: November 01, 2005, 07:35:03 pm »
Dave,
There's a good thread talking about coating the prechamber insert..
http://www.vwdiesel.net/phpBB/viewtopic.php?t=2329
Come and add your idea...
Marc/
2k1 Golf TDI, 11mm pump, HFLOX Warp 5, VNT17, Wavetrac, 4" Lift
91' VW Golf Country
94' Dodge RAM 2500, 4x4, Cummins, 5 spds, 191's, 215hp injectors, SB Clutch
03' Dodge RAM 2500, 4x4, Cummins, 6 spds, MBPR 4 ", custom intake, Smarty Jr
-> www.mikrotuning.com <-
-> www.hflox.com <-
Reply #3November 01, 2005, 08:18:22 pm
greggearhead
  • 153
Pre cup
« Reply #3 on: November 01, 2005, 08:18:22 pm »
Messed with 1.5/6/7 Gas heads on the flow bench back in the day when I was in college working at a VW/Porsche shop.
Also played with a broken diesel head.  Same valve sizes  and basic layout as the small valve gasser heads of course.  With the valves going down to the flat head surface instead of to a bathtub combustion chamber, there was a bit more downdraft after making the turn in the port, so all else being equal, the diesel heads flowed a touch more that the gasser.  (Not a GTI 8 Valve head or anything, but the 1.5/6/7).
Nice thing is that all the info and porting techniques for the early gas heads WORK on the diesel.  David Vizard wrote an article for Hot VWs in the very early 80s detailing exactly what and where to port, and it is very accurate.  Don't know if there are any port differences from the early 1.5/6 I messed with and a 1.6TD or the later 1.6 hydraulic heads?
I am sure the later 1.9 and 1.9TD heads are different and with bigger valves (right?).  On the gas engines, the 1.8 8V heads look very similar, but respond very differently to porting.  What works on the early heads doesn't work on the later ones - you can even have flow drop off for doing the exact same thing.  Anyone tried modifying and measuring the improvements on a later diesel head?
Caddy (TD Project), Caddy 1.6D, etc etc.
  Snow Performance Water-Methanol Injection
