Author Topic: Head Gasket Info  (Read 2279 times)
November 01, 2005, 09:45:10 am
bvanetten
  • 70
Head Gasket Info
« on: November 01, 2005, 09:45:10 am »
Here's a good example for an FAQ.  Part #'s Thickness's, Applications, etc.  In paticular, I need to know what you need to do to make a 1.9l gasket work on a solid lifter 1.6l head.  Is it possible?  If not what are the alternatives?
Thanks,
Bruce
Reply #1November 01, 2005, 10:03:54 am
RedRotors
  • 734
    • http://www.mikrotuning.com
Head Gasket Info
« Reply #1 on: November 01, 2005, 10:03:54 am »
There's a lot of info about head gasket, just use the search engine.. If you want to make a FAQ for this subject, no problem, but gather the info and then write the faq.
Marc/
2k1 Golf TDI, 11mm pump, HFLOX Warp 5, VNT17, Wavetrac, 4" Lift
91' VW Golf Country
94' Dodge RAM 2500, 4x4, Cummins, 5 spds, 191's, 215hp injectors, SB Clutch
03' Dodge RAM 2500, 4x4, Cummins, 6 spds, MBPR 4 ", custom intake, Smarty Jr
-> www.mikrotuning.com <-
-> www.hflox.com <-
