Author Topic: Difference between original 1.6 D and TD Vanagon oil pump.  (Read 2790 times)
January 13, 2010, 09:26:02 pm
DieselVanagon
  • 24
« on: January 13, 2010, 09:26:02 pm »
 ???Does anyone know the difference between the original 1.6 Diesel Oil pump and the legendary TD oil pump.
Does anyone have the OEM part numbers for the D and TD pump/
Reply #1January 17, 2010, 08:14:07 am
  • 1739
Re: Difference between original 1.6 D and TD Vanagon oil pump.
« Reply #1 on: January 17, 2010, 08:14:07 am »
Vag cat doesn't list separate ones anymore, if ever [ no evidence of delete or supersession] . the only thing mentioned is if it had a  vacuum pump for power brakes  The part # is 068 115 105 BP
Reply #2January 17, 2010, 02:16:35 pm
« Reply #2 on: January 17, 2010, 02:16:35 pm »
The oil circuit had to be adapted to the specific needs of the engine because of the higher thermal loading. In addition to the conventional pressurized lubrication system, oil lines with upwards directed jets are mounted in the crankcase at each cylinder to provide additional cooling of the piston bottoms. A lubrication circuit was also added for the turbocharger bearings. Both features are shown schematically in Figure 21. The oil from the turbocharger bearings flows back into the oil pan via a flexible tube. The oil pump capacity has been increased by approximately 15 % by an increase in the width of the pump gear from 26 to 30 mm. Before entering the oil fitter the oil flows through a heat exchanger, which is cooled by the engine coolant. Figure 22 shows the cooling of the piston bottom. This special oil cooling lowers critical piston temperatures by approximately 30 C.
