Author Topic: restrictive exhaust Qs  (Read 7226 times)
Reply #30January 27, 2010, 05:42:20 am
veector
  • 95
Re: restrictive exhaust Qs
« Reply #30 on: January 27, 2010, 05:42:20 am »
No egt or intercooler yet, hard to do work when you dont have a garage and its -5 outside.  I usually keep it under 15lbs with small spurts to 17 or 18.  Intercooler and egt gauge coming when it warms up!
GB-  I would definitely buy one if the pocket allowed, being a broke ass student thought doesnt seem like it will for a few more years
1981 Jetta D
1997 Jetta TD
Reply #31January 27, 2010, 10:27:31 am
« Reply #31 on: January 27, 2010, 10:27:31 am »
GB doesnt understand the whole "using your money for more important things" kinda life style. appearently he has more money than he knows what to do with. and everything he does is perfect, just ask him. hahaha.
i hear ya tho, gotta save the money to keep the car running, not to put TT exhaust on it.
Reply #32January 27, 2010, 12:02:56 pm
monkey magic
  • 120
« Reply #32 on: January 27, 2010, 12:02:56 pm »
guys, regardless of valve overlap and a need (or lack of need) for back pressure, you can have too big an exhaust.
It is said that if you go too big, the exhaust gasses expand too quickly, cool off, and slow down, thereby creating the very same back pressure you're trying to eliminate.
mm
mTDi syncro
Reply #33January 27, 2010, 01:13:57 pm
peacedub
  • 49
« Reply #33 on: January 27, 2010, 01:13:57 pm »
im thinking of doing a 3'' strait pipe with cherry bomb glasspack, do you guys think id have a problem passing inspection tho"?
Reply #34January 27, 2010, 06:35:06 pm
« Reply #34 on: January 27, 2010, 06:35:06 pm »
What's the best exhaust I can put on my 92 1.6l n/a ?
I have an all stock system and want her to breath better!
"Best" is highly subjective. On my 1.9NA I use a 8v GTI 4:2:1 stock header. I had to add a spacer though because the 1.9 is a bit taller then a 1.6. It will bolt on a 1.6. What you can also do is hollow out the bottom of the "toilet bowl" and increase it's diameter up to 2" or 2.25". I wouldn't go bigger then that on a NA. If you do some searching I think you will find what you need.
