Author Topic: restrictive exhaust Qs  (Read 7268 times)
January 13, 2010, 07:27:28 am
veector
  • 95
« on: January 13, 2010, 07:27:28 am »
I purchased and installed a giles superpump on my aaz along with a boost controller to get that k14 spinning 18-20lbs on full throttle.  Now i've still got the stock exhaust which was put in recently by the previous owner.  Downpipe, resonator mid muffler and end muffler.  That seems like alot holding back that exhaust pressure...  Would i benefit from deleting a few mufflers or would i need something else?
Thanks,
Vic
1981 Jetta D
1997 Jetta TD
Reply #1January 13, 2010, 08:45:11 am
Re: restrictive exhaust Qs
« Reply #1 on: January 13, 2010, 08:45:11 am »
Turbo, resonator, mid muffler and end muffler!? holy cow :P The turbo itself acts as a huge restriction.
I think if you were to 2.25-2.5" turbo back and just have an end muffler, you would notice a giant increase in performance.
Reply #2January 13, 2010, 08:50:31 am
« Reply #2 on: January 13, 2010, 08:50:31 am »
Yeah, even just the weight of the stock exhaust system is a limitation in itself - the "suitcase" resonator under the back seat is pretty heavy and absolutely unnecessary.
I put a Magnaflow cat-back on my gasser, it worked great.  It was a 2.25" though, so I left it on the car when I sold it.  Noticeable difference on the gasser, so I'd imagine the diesel would like it even better!
Does your car not have a cat on it?
Reply #3January 13, 2010, 10:09:02 am
« Reply #3 on: January 13, 2010, 10:09:02 am »
If you still have the cat then loosen off the 3 bolts so there is a huge leak there and take it for a spin an see if there is any difference. You should locktight the nuts on so they don't fall off and cause your exhaust to fall.
You'll get the bottom of your car sooty and dirty though.
Reply #4January 13, 2010, 03:49:06 pm
veector
  • 95
« Reply #4 on: January 13, 2010, 03:49:06 pm »
No cat on my car so i think im going to have a straight pipe made from the downpipe and exit in front of the back wheel.  Would i be killing my back pressure by doing that?  Most likely il have something fabbed up with just one end muffler
1981 Jetta D
1997 Jetta TD
Reply #5January 13, 2010, 04:23:15 pm
« Reply #5 on: January 13, 2010, 04:23:15 pm »
No back pressure is required since you have a turbo.
Look into upgrading the downpipe (custom) too if the pocket allows.
Reply #6January 13, 2010, 07:32:26 pm
veector
  • 95
« Reply #6 on: January 13, 2010, 07:32:26 pm »
Heh goes to show how much i know so i could run a straight pipe :)
I've got a good exhaust guy who im sure could fab up a custom downpipe.  What would be a decent size? 2 1/2, 2 3/4?
1981 Jetta D
1997 Jetta TD
Reply #7January 13, 2010, 08:26:25 pm
RadoTD
  • 513
    Stage WTF
« Reply #7 on: January 13, 2010, 08:26:25 pm »
With 20lbs of boost, I'd go at least 2.5".. more likely 3" from the turbo the whole way back :)
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #8January 13, 2010, 09:52:36 pm
dyoungen
  • 128
« Reply #8 on: January 13, 2010, 09:52:36 pm »
Back pressure is nessary on gassers but not Diesels. The better the Diesel breaths, the better she runs.
Reply #9January 14, 2010, 05:26:02 am
veector
  • 95
« Reply #9 on: January 14, 2010, 05:26:02 am »
awesome great info guys im sorta new to the diesel world.  Il be looking into a 3" dp then :)
1981 Jetta D
1997 Jetta TD
Reply #10January 22, 2010, 07:23:23 pm
veector
  • 95
« Reply #10 on: January 22, 2010, 07:23:23 pm »
Just spoke to my exhaust guy and he'll be fabbing up a 3" downpipe with flex hose, along with a side exit by the back wheel.  Straight through :D  Very good pricing too if anyone is looking for an exhaust guy in the west end of Toronto
« Last Edit: January 22, 2010, 07:25:12 pm by veector »
1981 Jetta D
1997 Jetta TD
Reply #11January 23, 2010, 11:28:29 am
MouseGTD
  • 110
« Reply #11 on: January 23, 2010, 11:28:29 am »
i made mine myself, only cost me 40 pounds for the piping
i couldn't believe how thin the original down pipe was on mine
standard
after
3" all the way, made a massive difference and makes a great noise when you let off the throttle ;D
« Last Edit: January 23, 2010, 11:52:07 am by MouseGTD »
Reply #12January 24, 2010, 08:32:59 am
« Reply #12 on: January 24, 2010, 08:32:59 am »
standard
after
if that thing ^ was on a n/a, you would not have hearing after driving 5 miles. n/a diesels are the LOUDEST thing i have EVER heard in my life.
Reply #13January 24, 2010, 09:15:19 am
MouseGTD
  • 110
« Reply #13 on: January 24, 2010, 09:15:19 am »
well it sounds nice on a turbo ;D
Reply #14January 24, 2010, 10:51:26 am
  • 1739
« Reply #14 on: January 24, 2010, 10:51:26 am »
But does that apply to non turbo's ?
