Author Topic: What Starters Will Fit???  (Read 2303 times)
January 13, 2010, 07:01:35 am
ein bora
  • 377
« on: January 13, 2010, 07:01:35 am »
More bad luck, I had my starter go this morning. Anybody know what starters are interchangeable with the 1.9 TD??
Thanks.
If you can't take advice - then you can't be helped!
Reply #1January 13, 2010, 08:10:27 am
MJF
  • 581
Re: What Starters Will Fit???
« Reply #1 on: January 13, 2010, 08:10:27 am »
What car?
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #2January 13, 2010, 11:51:57 am
ein bora
  • 377
« Reply #2 on: January 13, 2010, 11:51:57 am »
Reply #3January 13, 2010, 01:00:32 pm
54321chris
« Reply #3 on: January 13, 2010, 01:00:32 pm »
Can you not get another td starter?  I used a 2.0 gasser starter with mine for a little while, but the diesel starter is much more powerful.  I got a starter from the local parts store for a 97 jetta AAZ, since my car has the 02a transmission, and it works great.  Cost me 120.
Reply #4January 13, 2010, 02:10:16 pm
BleachedBora
  • Administrator
  • 104
    • Cascade German Parts
« Reply #4 on: January 13, 2010, 02:10:16 pm »
According to my info (which is usually right!  ;D) it's part number 068 911 023T, or Bosch part number SR34x. Both are readily available up there for you, they generally retail for about $150+$60 core. I also see an aftermarket one 020 911 024A which should work for you, it doesn't have a core and runs about $150 as well. If you have issues finding one let me know, but that should give you plenty of options! :)
Good luck!
-BB
'81 CBEA Caddy, '81 DeLorean, '98 Defender TDI, Too many VAG to list
www.cascadegerman.com
Sales and support: [email protected]
