Author Topic: 1.9 AAZ Intake/Exhaust Valve question  (Read 3678 times)
January 11, 2010, 04:55:27 pm
stomperz71
  • 52
« on: January 11, 2010, 04:55:27 pm »
I have a 1.9 AAZ engine that came out of a 1994 Golf. I'm rebuilding the enigine. My question is what Intake/Exhaust valve does this engine take? Is their more then one size valve for this engine?
Reply #1January 11, 2010, 05:22:12 pm
rallydiesel
  • 1880
Re: 1.9 AAZ Intake/Exhaust Valve question
« Reply #1 on: January 11, 2010, 05:22:12 pm »
There are two different stem sizes. Early versions had the 8mm stem and later ones had the 7mm stems. Smaller stems allow for more flow. You could go either way but get valve guides to match the stem diameter.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2January 11, 2010, 06:20:03 pm
stomperz71
  • 52
« Reply #2 on: January 11, 2010, 06:20:03 pm »
Ok thanks for that info..
I was reading some back post about different length also?
Reply #3January 12, 2010, 02:30:00 pm
stomperz71
  • 52
« Reply #3 on: January 12, 2010, 02:30:00 pm »
Anybody have part numbers? My parts guy is having trouble finding the right valve.  Thanks
The part numbers I have from the dealer are:
Intake # 028 109 601C
Exhaust # 028 109 611E
Them two number have different size stem dia. The Intake is 7mm and the exhaust is 8mm. The valves I took out of my head are both 8mm. The new valve guides I got are for 8mm valves. So I'm just wondering what the AAZ is suposed to have?
One other thing, my Bentley service manual has the AAZ valve spec as:
Intake Stem Dia. 7.97mm
Intake length 95.0mm
Exhaust Stem Dia. 7.95mm
Exhaust Length 95.0mm
I'm just real confused!!! ???
« Last Edit: January 12, 2010, 02:53:12 pm by stomperz71 »
Reply #4January 12, 2010, 03:11:03 pm
« Reply #4 on: January 12, 2010, 03:11:03 pm »
If you are going for a performance build then
Air Cooled Engines Plus, local profile:
Address: 286 2nd Avenue
City: Tiffin
State: Ohio
ZIP: 44883
Phone: (419)443-8987
 got me stainless versions for less money than stock...For a little more money he will undercut and swirl polish them. I think his name was John. Sorry for not being able to help your OP
Reply #5January 12, 2010, 03:23:46 pm
rallydiesel
  • 1880
« Reply #5 on: January 12, 2010, 03:23:46 pm »
Try these (should both be 8mm but I'm not 100% sure, taken from vagcat):
Intake: 069109601F
Exhaust: 074109611
I'm pretty sure the part numbers you posted are both for the 7mm stems.
Reply #6January 12, 2010, 04:43:19 pm
stomperz71
  • 52
« Reply #6 on: January 12, 2010, 04:43:19 pm »
Intake: 069109601F
Exhaust: 074109611
Your right on the Exhaust #074109611 that is a 8mm stem, 95.50mm length. I did get that one today.
I'll have to check on the that Intake #.
Reply #7January 12, 2010, 04:44:59 pm
stomperz71
  • 52
« Reply #7 on: January 12, 2010, 04:44:59 pm »
City: Tiffin
State: Ohio
ZIP: 44883
I talked to that guy a long time ago I'll have to check back with him and see if he can help me out. I'm about an hout from Tiffin. Thanks
Reply #8January 12, 2010, 05:30:41 pm
« Reply #8 on: January 12, 2010, 05:30:41 pm »
I didn't even pay attention to where you were from. Cool. Hope it works for you.
