VWDiesel Blog
Facebook Group
VWD on Twitter
General Information
FAQ/Tech Tips/Please Read First
Frozen E-brake cables
Topic: Frozen E-brake cables (Read 5321 times)
January 09, 2010, 10:14:02 am
January 09, 2010, 10:14:02 am »
Not mine but it looks useful.
http://forums.vwvortex.com/zerothread?id=4702625
January 12, 2010, 01:12:36 am
FineFrank
Re: Frozen E-brake cables
January 12, 2010, 01:12:36 am »
It's way cheaper and easier to clamp a piece of appropriately sized rubber fuel line to the end of the (brake/clutch/throttle) cable, add oil, and either let it drip through or add a little air (regulated) pressure. I've ressurected a couple cables (on a Caterpillar grader, for one) that I thought were goners. I always use this method when installing new cables on anything.
Frank Longtine
1983 Rabbit Diesel 4 dr/ 1.6NA
1997 Rokon Trailbreaker
1984 Ford F-150/ 300-6
"The welfare of humanity is always the alibi of tyrants" -Albert Camus-
April 27, 2010, 12:27:53 pm
Rabbit79
Burns, Oregon,USA
April 27, 2010, 12:27:53 pm »
I used to run an old 600 Prentice log loader that had about a dozen of these type of cables on it and they gave me a lot of trouble. Seemed every year I'd have to replace one or two of them. I tried just about every petroleum based lubricant you can get....grease, motor oil, WD-40, whatever. One day I was in the parts store and was asking one of the guys about this problem and he hooked me up with a little bottle of dry graphite lubricant. I just poured it in from both ends and shook it around and ran the cable through a bunch until it was well distributed. I started using that and it sure cut down on my cable problems. I think perhaps that since it's a dry lubricant it doesn't attract so much dirt and grit. Not saying it's the grand champion of all fixes, but it sure worked for me.
Current: 1979 Rabbit 4dr
1984 F-250
1999 Ford Ranger
Other v-dubs I've owned:
84 Rabbit
78 Rabbit (gasoline) flipped it end over end after driving all night and falling asleep at the wheel. RIP, it was a good little car.
70 Bug
April 27, 2010, 10:36:53 pm
April 27, 2010, 10:36:53 pm »
One of the funniest tricks i've seen was for freeing up past american style cables. The ones that are flat wire wound around the sliding cable , without any other sheathing or protection. Of course they would freeze up if not lubed. Get a car battery, some jumper cables and attach one jumper to an end of the cable and then the other at the other end, wait a few seconds until it gets red -NOT TOO RED ! While laughing hose down with cold water. Soak it with ATF [or whatever] . Fun
April 28, 2010, 01:24:25 am
Rabbit79
Burns, Oregon,USA
April 28, 2010, 01:24:25 am »
That IS an interesting fix. Wonder how they came up with that idea?
1984 F-250
1999 Ford Ranger
84 Rabbit
70 Bug
April 28, 2010, 12:49:41 pm
April 28, 2010, 12:49:41 pm »
my favorite is cut a chunk of intertube out and hose clamp it around the cable, then add oil of your choice and hang the cable.
getting a cable red hot and soaking it in ATF would be fun too tho!
May 03, 2010, 12:15:10 pm
clbanman
Cambridge, Ontario
May 03, 2010, 12:15:10 pm »
Quote from: Rabbit79 on April 28, 2010, 01:24:25 am
A toaster.
Calvin
91 VW Golf 1.6NA 5spd
General Information
