Author Topic: Rejuvinating a poorly SB.....  (Read 2157 times)
January 08, 2010, 01:40:49 pm
Jimmy Oldskool
  • 9
« on: January 08, 2010, 01:40:49 pm »
The SB in my MK2 Golf van is extremely poorly (Head Gasket :'( )
There are 2 options open to me at the minute......
To rebuild it, but want to build it strong and able to run lots of boost (was running 20psi through a K14 when it went pop!)
What is needed to stop it coming apart again?
I've been told to use a 1.9 head gasket and 1.9 Nozzles.....The question is, what 1.9 HG do I use and if the 1.9 nozzles give noticeable gains, which ones do i need?? ???
OR......
I have an AAZ available to me to transplant into the van......
Is the AAZ as tuneable as the SB? Is there much wiring/loom work involved in an AAZ transplant?????
Please help me!!!!  :'( :'( :'(
Reply #1January 08, 2010, 03:32:40 pm
  • 1739
Re: Rejuvinating a poorly SB.....
« Reply #1 on: January 08, 2010, 03:32:40 pm »
uhh, sorry, a SB ?
Reply #2January 08, 2010, 03:47:25 pm
Jimmy Oldskool
  • 9
« Reply #2 on: January 08, 2010, 03:47:25 pm »
uhh, sorry, a SB ?
A 1.6 GTD engine......
Reply #3January 08, 2010, 07:31:48 pm
« Reply #3 on: January 08, 2010, 07:31:48 pm »
If your's is hydro liftered then the AAZ HG will swap right on. That said IIRC, the AAZ doesn't have more wiring than you already got.
