Anybody have a pic of a boost gauge install?
Topic: Anybody have a pic of a boost gauge install? (Read 2746 times)
October 20, 2005, 04:16:00 pm
94GolfTD-MK
October 20, 2005, 04:16:00 pm »
Looking for a pic of where you T the boost gauge line
Thanks
Mike
October 21, 2005, 12:21:45 am
Maarten
October 21, 2005, 12:21:45 am »
Between the line from the intakemanifold to the injectionpump is best of the pressure that the engine recieves, or in the line to the wastegate is for checking the pressure that the turbo is acutally blowing.
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
October 21, 2005, 06:59:17 am
veeman
October 21, 2005, 06:59:17 am »
As Maarten said, I opted for the thin vacuum line between the intake "elbow" and the pump. It seemed a lot easier than trying to tee into the thicker wastegate line on the turbo.
Not sure what gauge you'll be using, but consider using one of the new tee's that has the built in restrictor to eliminate needle bounce. I've got one and it works great!
There's more info here....
http://www.newsouthperformance.com/fitting.htm
and a bit of discussion here...
http://www.vwdiesel.net/phpBB/viewtopic.php?t=1809
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
