Author Topic: Fuel filter question  (Read 2152 times)
January 07, 2010, 10:02:22 am
ein bora
  • 377
« on: January 07, 2010, 10:02:22 am »
Had some contaminate issues with my pump and injectors - does anybody know what the micron's are for the vw canister diesel fuel filters?? I'm thinking about adding a second filter, and would like to use an even finer one.
Any help appreciated. Thanks.
If you can't take advice - then you can't be helped!
Reply #1January 07, 2010, 10:53:43 am
maxfax
  • 2126
Re: Fuel filter question
« Reply #1 on: January 07, 2010, 10:53:43 am »
The most common one's on the market are 10 micron..  Never saw anything higher than that..   I think I have seen some higher end filters that are 5 micron..   I've seen alot of people use Baldwin and Standyne 2 micron filters and housings...
Reply #2January 07, 2010, 10:59:47 am
ein bora
  • 377
« Reply #2 on: January 07, 2010, 10:59:47 am »
Actually just bought a Standyne filter set up from giles who's also just done a performance rebuild on my pump. This has a glass bowl on the bottom as well as being a double filter.
Thanks for the info.
Reply #3January 07, 2010, 12:17:18 pm
maxfax
  • 2126
« Reply #3 on: January 07, 2010, 12:17:18 pm »
You're good to go!
Reply #4January 07, 2010, 07:51:36 pm
« Reply #4 on: January 07, 2010, 07:51:36 pm »
Just remember when you swap from the "normal flow filter" that will come attached to the filter head to the 2 micron "reverse flow filter" you will need to swap the lines around on the filter head.
Give Giles a call if that doesn't make sense (I doubt it does)
