Author Topic: I have a few question, New to GTD tuning...  (Read 5785 times)
January 07, 2010, 05:53:07 am
ScottSummerhayes
  • 15
« on: January 07, 2010, 05:53:07 am »
Right people, sorry for all the questions before i start. I am new here, i have a 86' Golf Mk1 Caddy and a 94' GTD 1.6TD Passat that i have stripped the engine out of.
I going to re-build it plus tune it as much as possible before dropping it into the caddy (still need to be reliable, aiming for around 160bhp) i have lurked here for a while and only just signed up. I am also a member of Vwcaddy.com...
Anyway, i have a few questions that i'm not sure about:
1) Would i gain anything from having the GTD head ported and polished? I am aiming for around 25-30psi boost. Or could i use the "Apparently " better 1.9 AAZ head? if so, will that bolt straight on? I have a 3 notch metal gasket and 12mm ARP studs.
2) What clutch size, and what would be the best type? The GTD engine will be bolted direct to the Stock 4-Speed box, i have found many different sizes (190mm, 200mm and 210mm)...
3) Does anyone know what size and pitch the thread is in the sump? I want to get one of those magnetic sump bolts...
4) What would be the best oil to run, 5w-30? It has just under 100k on the clock.
Again, sorry for all the questions. I'm sure there will be many more.... ;D
I will keep you all updated, here is a video before i took the engine out (it also shows my caddy  :) )
Part one of Caddy Engine Conversion, Finding the donor car...
Reply #1January 07, 2010, 06:24:23 am
TurboJ
  • 661
Re: I have a few question, New to GTD tuning...
« Reply #1 on: January 07, 2010, 06:24:23 am »
1. Yes you would, but the AAZ head IS better. The AAZ head flows a lot better, and if you do some porting/polishing work on the AAZ head, you will never look back. You'll get the same power with lower boost that way, meaning better reliability, simple as that. And yes, it will bolt right on, since your Passat engine is a hydraulic lifter engine.
2. Get a 02A gearbox. You can find one with suitable gearing from mk3 TDI, or Passat TD / TDI. It's pretty simple to swap it on, and the 02A is much nicer to use, much stronger and allows you to use the popular 228 mm solid flywheel, for which there is a multitude of good clutch packages available ( which can not be said about 020-family boxes).
And, if you decided to try it out with your original 4-speed box, you'd realize in a day why everybody always swaps in a long-ratio gearbox :)  The 4-speed will not work with a tuned engine, period.
3. Nope, I'm looking for one too, best just to take the bolt with you when you go out to buy the magnetic thing.
4. 5W-40 fully synthetic, with API CF rating at least. Steer well clear of the 0W-30 "long life" oils, and 5W-30 "old school" mineral oils have no benefits whatsoever, to merit their use. They should never be used on a turbocharged engine. Best bet is to use a diesel-specific 5W-40, like Mobil Delvac, but there are good options out there.
EDIT: Are you sure your Passat is '94 AND 1.6 TD? I thought they'd all be AAZ by that year, but yeah, the engine on the video definetely is a 1.6. But anyway, you'll find all that you need for your gearbox swap on that very Passat! Just take the pedals, gear stick + cables, master cylinder + bracket, slave cylinder plus fluid line and reservoir, and you're good to go! You might even find a suitable clutch assembly on that Passat, just make sure it has a solid flywheel. You'll save a bucketfull of money if you can use all the Passat stuff without having to source the parts separately! There is only a little custom work involved with the gearbox mount, and drive shafts, other than that it's quite simple.
« Last Edit: January 07, 2010, 06:31:41 am by TurboJ »
Jetta II 1.6 TD 'Project 200'
Reply #2January 07, 2010, 07:20:19 am
ScottSummerhayes
  • 15
« Reply #2 on: January 07, 2010, 07:20:19 am »
Thanks for the help TurboJ! Lots of good answer there..
1) Awesome, i can get one for a good price in decent condition. I will go down the route of getting the AAZ ported and Polished :) EDIT: i have done some searching and it seems that most people are getting awful running with a 3 notch gasket and the AAZ head due to the much lower compression...i'm now unsure what to do?
2) I really don't think i can do the gearbox change, it sounds way out my depth to be honest! When you say the 4-speed will not work, How exactly do you mean? I'm not worried if flat out im only getting like 60-70mph. I can't see why it would be much different to the 1.6NA i already have...surely it will just be quicker?
3) I was going to get one from ebay, nevermind this isn't important right now!
4) Thanks for the Oil Info, big help!
And yes my 94 Passat is definitely a GTD, its got the SB engine code and the intercooler! I think it must of been the LAST EVER GTD created. It was a hard find, but well worth it as its only just under 100K on the clock, full service history and one elderly driver from new.
I really don't think i can take on modifying all the gearbox and drive shafts. I will have a look at it tonight and see if i can get my head around it...
« Last Edit: January 07, 2010, 08:38:03 am by ScottSummerhayes »
Reply #3January 07, 2010, 11:07:12 am
« Reply #3 on: January 07, 2010, 11:07:12 am »
ok, the first thing you CANT DO, is put a retarded 4 speed back in there. build yourself a good back yard fire (a good hot one) then pitch that 4 speed in there. it will be worth it. so will the hole melted in the ground. but anyway, the reason 4 speeds are retarded, is because they have super low gears, and almost no over drive. if you got lucky to have a 3+E box, then it has a nice low .71 4th gear. that would be alright, but a GC or GP, waste of time. you get no mileage out of them, its hard to load the turbo enough to get boost out of it, and the boost drops considerably more in between shifts, rather than with a 5 speed. my car used to drop to almost 0 psi boost between shifts, just because the engine dropped too many rpms. with the 5 speed, i wouldnt even drop below 10 psi between shifts. and i would be able to hold each gear longer and get more boost out of it. plus, i did get better mileage from the 5 spd. an ACN 5 speed out of a mid eighties jetta will do good. AGS does good too, so does another gas model, along with about every diesel 5 speed available. AVOID AN AVX...
GET RID OF THE 4 SPEED!!!
Reply #4January 07, 2010, 12:59:46 pm
TurboJ
  • 661
« Reply #4 on: January 07, 2010, 12:59:46 pm »
Well said, Rabbit!
That's exactly what I meant too..
Scott, if you don't like the idea of using the Passat gearbox, at least get a high-geared 5-speed 020 like Rabbit on Roids suggested. You can find the different gear ratios by googling vw 020 etc.
The longest ratios are the best, since you're tuning your engine way beyond any of the OE diesel engines of the day, so you won't find too high gearing on any box of the era. With the 02A's you would have the possibility of using a Golf III or Passat B3 TDI gearbox - those have the longest gearings. With that, you would have the most out of your tuned engine.
I almost wish I had a TDI box too, but my Passat TD one will do just fine since I'm going to rev my engine well beyond 6000 rpm.
Please don't contemplate on using the 4 speed  :D  Unless you enjoy taking the engine/gearbox in and out of the engine bay!
Reply #5January 07, 2010, 02:48:23 pm
ilikevwdiesel
  • 1202
« Reply #5 on: January 07, 2010, 02:48:23 pm »
That is a SWEET Caddy bro ;D
My Bio
Reply #6January 08, 2010, 03:22:12 am
ScottSummerhayes
  • 15
« Reply #6 on: January 08, 2010, 03:22:12 am »
Cheers mate, you wait till its finished in a few months. Its going to look the tits, along with the engine its getting a total overhaul. I have a new Mk1 GTI interior going in (with all new carpets etc), i am also using MK3 Cloth Black Recaros that look AWESOME...
Some new wheel once everything else is done, something a little exotic...
Ok it seems like using the 4-speed box is a No-no! I'm glad i spoke to you guys, you HAVE BEEN SO HELPFUL! I am more than happy to drop a 5-Speed in, i just don't feel like messing around with a 02A box (seems like a LOT of work). So i am now on the hunt for the "Longest" ratio 5 speed i can find, What Gearbox codes should i look for? and where on the box are they?
again, THANKS FOR ALL THE HELP. I wish i could repay you all somehow  ;)
Reply #7January 08, 2010, 04:39:08 am
regcheeseman
  • 714
« Reply #7 on: January 08, 2010, 04:39:08 am »
Hi bud!
Try to source a late UK 4+E caddy five speed box, they have a tall 5th (FF code I think) also try a FN, FH, or FJ all are listed as 83mph in fifth at 3500rpm.
I ran one in my old cad and coupled to 15" and 16" rims - good for 120 on my private road.
Reply #8January 08, 2010, 05:38:59 am
TurboJ
  • 661
« Reply #8 on: January 08, 2010, 05:38:59 am »
On a 5-speed 020, the gearbox type code is stamped on the clutch housing, right at the bottom of the thing, so you'll see if from underneath the car if it's still fitted. On 02A, the code is stamped (with very thin letters) on the top side of the gearbox, facing upwards, to the front of the car, next to the clutch housing.
Reply #9January 08, 2010, 06:03:39 am
ScottSummerhayes
  • 15
« Reply #9 on: January 08, 2010, 06:03:39 am »
Hi bud!
Hello Reg mate, i finally signed up on here :)
I have found a box at a reasonable price (well a little more than i would like but i need it...) the code is 4Y? what would that be like? Or would you know of a decent box for sell?
I'm always very scared of buying a nackered gearbox and getting ripped off, the 4-speed i have now is perfect. Hence why i wanted to use it...Is there anything i should look at out? (will probably be hard as its going to most likely be a online buy)
To be honest i'm not worried about the top speed at all, as long as i can get to 70mph im happy! I do however want to get to 70 like *** off a shovel.
I will always lose some top end as i'm a 13" man myself  ;)
EDIT: Thanks TurboJ, I will make sure to get the code before i buy any box.
Reg: You don't feel like coming round and fitting my passat 02A box for me do you? I don't think i'm capable to be honest...
EDIT2: Some guy just gave me another code of: Acd19088. Whats the deal with that one?
« Last Edit: January 08, 2010, 09:07:35 am by ScottSummerhayes »
Reply #10January 08, 2010, 07:48:33 pm
« Reply #10 on: January 08, 2010, 07:48:33 pm »
Here's some super good info,
http://www.brokevw.com/020ratios.html
http://www.scirocco.org/gears/
The ACD is the code and 19088 is the coded date it was made, all these tranny's have both the code and date like that.
This, http://www.brokevw.com/020oil.html shows how to decode the date, I've never figured it out. ;D
Reply #11January 09, 2010, 12:42:44 pm
LoneWolf
« Reply #11 on: January 09, 2010, 12:42:44 pm »
oil wise just use a decent quality 10w 40 or 15w 40, theres no reason youd need a thinner oil than that, besides, VW sent them from the factory with the thicker oil, so it must be capable of doing the job
Reply #12January 10, 2010, 04:58:09 am
TurboJ
  • 661
« Reply #12 on: January 10, 2010, 04:58:09 am »
There is the need for thinner oil if the engine is tuned to 160 hp  ;)
Reply #13January 10, 2010, 08:28:48 am
« Reply #13 on: January 10, 2010, 08:28:48 am »
5w40 or something for the 160 horse and up engines?
Reply #14January 10, 2010, 12:09:34 pm
ScottSummerhayes
  • 15
« Reply #14 on: January 10, 2010, 12:09:34 pm »
Really? I think i will try it with the thicker to start with.
Also as i was thinking about gearboxs, Will this effect my drive-shafts? Obviously some Mk1 Golfs have different 90 or 100mm Driveshafts?
I hope this doesn't effect mine :(
If so, can i use the drive shafts off the 94' Passat, even with the 02A Box and none 020...???
Thanks
Scott
