Author Topic: Can you mix synth with convec oil?  (Read 2198 times)
January 06, 2010, 09:41:25 pm
  • 3468
    • McScrubbins Body Wash
« on: January 06, 2010, 09:41:25 pm »
I'm running convectional for break in and i want to top it up just a bit, can i add either clean or very lightly used synthetic?
I seem to recall they wont mix but that may be a myth.
there is semi-synthetic oils so im assuming they do.
Reply #1January 06, 2010, 09:50:44 pm
Re: Can you mix synth with convec oil?
« Reply #1 on: January 06, 2010, 09:50:44 pm »
I don't think it's a good idea to use synth on break in, it'll lube the rings so good that they'll glaze over rather than seat. ;)
Reply #2January 06, 2010, 10:58:05 pm
cyrus #1
  • 360
« Reply #2 on: January 06, 2010, 10:58:05 pm »
x2 on this.  You can mix the two with no problems though.
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #3January 06, 2010, 11:57:55 pm
  • 3468
« Reply #3 on: January 06, 2010, 11:57:55 pm »
oh yes i know. Pretty sure the break in is over now. 2 tanks of D later... or should i hold out even longer?
Reply #4January 07, 2010, 04:41:00 am
macka
  • 957
« Reply #4 on: January 07, 2010, 04:41:00 am »
the big myth here is the rings seating. If they didn't seat right away your engine wouldn't run, and you'd get a hell of a mess in your oil pan. We also hone the walls to promote the seal. It takes a long time to get the hone pattern out of the cylinder walls, and by then you'll know if you did the job right or you have to do it over again.
Quote from: Vincent Walden
