Author Topic: Source for rabbit fuel tank cap?  (Read 3219 times)
January 06, 2010, 02:50:41 pm
ldeikis
  • 56
« on: January 06, 2010, 02:50:41 pm »
I'm 99% sure some joker thought the old school thread-in cap on my rabbit was cute and swiped it for no good reason.  There is a 1% chance I left it at the gas station, but I know where I filled up, it was only a day ago, and the guys there know me and wouldn't feed me BS about not having found one.
Either way I need a new one.
Problem is, I never paid a whole lot of attention to the anatomy of my cap, and now I find there's all kinds of different ones for sale...  and none of them reference whether it'll fit a diesel car (I feel like our filler holes are different--fatter--and don't have that little metal flap, right?  Do these things matter to the cap?).  The car's an 81 square headlight (westy) rabbit (diesel).  I have no recollection of whether it was threaded or just had tabs or what.  The hole itself has two little notches at 3 and 6 o'clock.  I have no reason to think the car doesn't have the original fuel tank.
Can anyone tell me if the cap sold for any old 81 rabbit will fit, and if not, where I can find a diesel one?
The car lives outside and is my only transportation, so it's got a sock stuffed in there, but it looks like ass and I don't imagine seals too well.
Thanks,
Luke
« Last Edit: January 06, 2010, 02:52:37 pm by ldeikis »
81 Rabbit 1.6 N/A
Reply #1January 06, 2010, 04:30:18 pm
macka
  • 957
Re: Source for rabbit fuel tank cap?
« Reply #1 on: January 06, 2010, 04:30:18 pm »
give jack a shout
[email protected]
his website is www dot vwdieselparts dot com  he is located in Ohio
Quote from: Vincent Walden
Reply #2January 06, 2010, 05:15:36 pm
ldeikis
  • 56
« Reply #2 on: January 06, 2010, 05:15:36 pm »
I stopped in in person at the gas station this evening (I'd called on the phone before and been told they hadn't found one) and, lo and behold, there is my cap.   So crisis averted.
I am curious, now, though--the MK1 gasser cap is different or the same?
81 Rabbit 1.6 N/A
Reply #3January 06, 2010, 06:09:52 pm
« Reply #3 on: January 06, 2010, 06:09:52 pm »
It's so embarassing to be 100% wrong ;D
Reply #4January 06, 2010, 07:24:03 pm
« Reply #4 on: January 06, 2010, 07:24:03 pm »
I've never actually tried swapping gas to diesel caps but I would suspect they are the same. Obviously the tab vs threaded ones will not interchange. One thing to be aware of is that the diesel needs a vented cap and most gas ones are not vented.
Reply #5January 06, 2010, 10:00:05 pm
« Reply #5 on: January 06, 2010, 10:00:05 pm »
Come to think of it, a few years ago I left mine on the car roof and drove off, so I swiped it from my gasser parts rabbit. I don't know if it's vented or not but it's work fine all along.......then I did the same thing a month or two later but then I pedal biked up and down the road until I found it :D.
Reply #6January 07, 2010, 03:35:22 pm
GEE-BEE
  • 1604
« Reply #6 on: January 07, 2010, 03:35:22 pm »
I was informed that the locking caddy cap was the same for diesel and gas  ?
If not I will drill a vent hole in my cap...
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #7January 07, 2010, 04:06:20 pm
ilikevwdiesel
  • 1202
« Reply #7 on: January 07, 2010, 04:06:20 pm »
I have an 82 US Rabbit diesel out in my dooryard if anyone needs a fuel cap.  ;D
My Bio
Reply #8January 07, 2010, 07:26:31 pm
« Reply #8 on: January 07, 2010, 07:26:31 pm »
I haven't studied the mk1 fuel tank, it may be vented some other way then the cap.
Reply #9January 08, 2010, 08:57:33 am
GEE-BEE
  • 1604
« Reply #9 on: January 08, 2010, 08:57:33 am »
I removed the charcoal canister in the LH fender, there was a line from the filler to this canister and return to a Y connector.
Iam not sure if diesel models had this also ?
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #10January 08, 2010, 09:56:47 am
« Reply #10 on: January 08, 2010, 09:56:47 am »
my rabbit cap has no vents on it, its the kind you turn a quarter turn, pull it out some, then turn it another quarter turn.
Reply #11January 08, 2010, 07:34:18 pm
« Reply #11 on: January 08, 2010, 07:34:18 pm »
There's a vent hose that goes into the right side frame rail, it's weird though, with the tank under lung pressure the vent barely hisses at all ???
