Author Topic: Prothe pistons...what's the verdict?  (Read 6989 times)
January 03, 2010, 09:28:34 am
hamradio
  • 282
« on: January 03, 2010, 09:28:34 am »
So,
Has anyone had any experience with the prothe pistons?  $189/set is enticing, but I worry about quality.
Thanks.
-Devan
Reply #1January 03, 2010, 09:31:27 am
Re: Prothe pistons...what's the verdict?
« Reply #1 on: January 03, 2010, 09:31:27 am »
i know someone, maybe smokey eddy is running a set of his pistons. im going to be inclined to buy a set also for my 1.6 build. im gonna opt for total seal rings tho, rather than whatever they come with.
Reply #2January 03, 2010, 09:42:34 am
Powered by Spearco
  • 1203
« Reply #2 on: January 03, 2010, 09:42:34 am »
I'm running a set of TD pistons from Prothe. The rings that came with them are junk, only because one was broken upon opening for inspection. I'm using a set of Goutze rings with no problems so far, and thats running lots of fuel and boost.
Others might say different due to their experience.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #3January 03, 2010, 10:20:03 am
Dakotakid
  • 1240
« Reply #3 on: January 03, 2010, 10:20:03 am »
Two sets put to work with their original rings last year. Both engines are N/A application. Each engine now has roughly 10,000 miles. The machinist said the pistons spec'ed out very well. Both engines had their rings seat quickly and any oil usage is (for practical purposes) non-existant at this time. Can't complain at this point.
Reply #4January 03, 2010, 10:32:18 am
« Reply #4 on: January 03, 2010, 10:32:18 am »
and the fact that a company with a good reputation builds these pistons. they supply oem pistons for ford and isuzu if i remember right. prothe just has the connection to the company is all. i think the pistons are probably the best product he sells honestly.
Reply #5January 03, 2010, 10:35:45 am
Powered by Spearco
  • 1203
« Reply #5 on: January 03, 2010, 10:35:45 am »
Whats the brand name of the pistons? Something like "Quality" right.
'13 Golf R:. Tuned
'98 Puch G320
Reply #6January 03, 2010, 10:41:22 am
« Reply #6 on: January 03, 2010, 10:41:22 am »
crap, i cant find the page where i saw it, but it had the suppliers name, and certifications once upon a time.
Reply #7January 03, 2010, 11:16:23 am
« Reply #7 on: January 03, 2010, 11:16:23 am »
Why support a guy that continues to rip people off with his garbage pumps? There must be other cheap sources for pistons?
Reply #8January 03, 2010, 11:35:55 am
maxfax
  • 2126
« Reply #8 on: January 03, 2010, 11:35:55 am »
Prothe get's the pistons from Right Way Industrial...   I did some checking up on the company and the do indeed supply alot of OEM stuff.. I bought a set, have yet to get the engine installed and try them out, but they guys at the machine shop seemed pleased with them, and they be some picky mo-fo's..
I have to side with Burn on this though..  I did buy a set from Prothe It'll probably be the last thing I ever buy from him. He's screwed too many people over with his pumps.. If he'd get out of the pump "rebuilding" he could quite possibly be a somewhat reputable seller..
There has to be someone out there that also has the same connection to source these..  Yeah they may not be OEM but I just can;t see putting $400 bucks worth of pistons in a car worth $800... Bang for the buck they seem alright...
Reply #9January 03, 2010, 04:27:03 pm
410
  • 581
« Reply #9 on: January 03, 2010, 04:27:03 pm »
I bought a set of his pistons for my m-tdi project and so far so good.  I do wish I had used better rings though.  I do burn a little bit of oil still.  I  have about 5000 km on these pistons now running 20 psi and a heavily modded pump.
I also noticed that the oil ring is not completely supported close to the wrist pin.  I wonder if this could my oil consumption issue.  This is noticeable in the pics on his web page.  I haven't had a close look if the 1.6 pistons are the same.
Reply #10January 04, 2010, 06:22:12 am
deathhare
  • 74
« Reply #10 on: January 04, 2010, 06:22:12 am »
A little more money but made in germany.....Kolbenschmidt ftw.
 http://www.thedubdoctor.com/parts_site/idiparts.html
Reply #11January 04, 2010, 07:02:47 am
« Reply #11 on: January 04, 2010, 07:02:47 am »
that gets us right back to the 400 dollar problem. we were looking for cheap pistons. we can get mahles from Myke on here for like 85 bucks a piece.
Reply #12January 04, 2010, 10:13:52 am
« Reply #12 on: January 04, 2010, 10:13:52 am »
I think Smokey Eddy is running a prothe 1.9 head on his 1.6td. I'm fairly certain that thing gets abused (30 psi regularly lol), and its still goin.
Reply #13January 04, 2010, 11:14:55 am
« Reply #13 on: January 04, 2010, 11:14:55 am »
Thedubdoctor and Myke are one and the same ;D
Reply #14January 05, 2010, 08:16:39 am
deathhare
  • 74
« Reply #14 on: January 05, 2010, 08:16:39 am »
400 dollars is CHEAP!  ???
