Author Topic: Anemic Audi!  (Read 6599 times)
December 30, 2009, 06:14:22 pm
colectb
  • 93
Anemic Audi!
« on: December 30, 2009, 06:14:22 pm »
My Audi 5000 Turbo Diesel just recently became Anemic. I don't have time to start working on it until the weekend, so I thought I would like to get some suggestions to see where to start. Its most likely a breathing ( intake or exhaust) issue.
Here are the symptoms:
-It will NOT go above 3000 rpm and therefore will not pass 65 mph (~100 kph)
-I don't get my rather annoying black cloud anymore while flooring it, and I get about 1 psi less boost at full throttle.
-It idles and runs in lower rpms perfectly.
So it could be a plugged muffler, although I see exhaust smoke, just not soot. It could be something to do with the intake, or it could even be a fuel problem. Any suggestions?
Thanks in advance!
1986 Porsche 944 NA
1983 Audi 5000 Turbo Diesel
Reply #1December 30, 2009, 06:31:39 pm
veedubcanuck
  • 151
Re: Anemic Audi!
« Reply #1 on: December 30, 2009, 06:31:39 pm »
Sounds like a fueling issue over a restriction in the intake or exhaust. Maybe your pressure line to your LDA came off or there is something wrong with the pump... Did your floor mat slip under your throttle pedal? lol
Reply #2December 30, 2009, 09:13:01 pm
Re: Anemic Audi!
« Reply #2 on: December 30, 2009, 09:13:01 pm »
Restricted fuel supply is my guess. Most likely suspect would be the fuel filter.
Reply #3December 31, 2009, 10:16:22 am
Re: Anemic Audi!
« Reply #3 on: December 31, 2009, 10:16:22 am »
im going with the clogged fuel filter too. my 5000 ran 100x better when i put a new filter on it. i fought fuel problems for days with it, then changed the fuel filter and it ran like a champ.
Reply #4December 31, 2009, 02:31:04 pm
colectb
  • 93
Re: Anemic Audi!
« Reply #4 on: December 31, 2009, 02:31:04 pm »
Ok cool, I was going to replace it anyways and a new one is in the mail, but it seems kind of strange because I changed the filter a couple months ago. I must have a lot of crud in my fuel tank.
1986 Porsche 944 NA
Reply #5December 31, 2009, 05:58:20 pm
Re: Anemic Audi!
« Reply #5 on: December 31, 2009, 05:58:20 pm »
its not a bad idea to buy a cheap vacuum gauge and install it from the filter to the pump.
Reply #6December 31, 2009, 06:10:28 pm
TPW
  • 113
Re: Anemic Audi!
« Reply #6 on: December 31, 2009, 06:10:28 pm »
Cole, there is another fuel screen inside the fuel tank.  I replaced that filter about 10 years ago, and there have been a lot of miles put on that car since then.  Lift up the lower part of the back seat to expose the access for the fuel gauge sending unit.  Hopefully the tank is half empty or removing the cover will let fuel flow into the passenger compartment.  I don't know how to describe the process for removing the screen (check the Bentley) but it is a plastic piece shaped like a shot glass under the sending unit.  Be sure to replace it with another coarse screen, as the gas 5000's have a finer mesh screen that will clog up with wax when the fuel gets cold.
Reply #7January 01, 2010, 12:35:05 pm
colectb
  • 93
Re: Anemic Audi!
« Reply #7 on: January 01, 2010, 12:35:05 pm »
Thanks Tom! I would have never thought of that nor known of that. Where did you get the replacement one at?
1986 Porsche 944 NA
Reply #8January 01, 2010, 12:36:29 pm
colectb
  • 93
Re: Anemic Audi!
« Reply #8 on: January 01, 2010, 12:36:29 pm »
Also Tom, you wouldn't happen to have any 5000 gasser intercooler piping lying around that I could buy from you, would you?
1986 Porsche 944 NA
Reply #9January 01, 2010, 01:23:58 pm
TPW
  • 113
Re: Anemic Audi!
« Reply #9 on: January 01, 2010, 01:23:58 pm »
No extra intercooling pipe.  On that car I just used straight pipe and radiator hose for the bends.  The Filter Screen I got at the dealership.  The closest ones for you are in Fargo, or Maplewood.
Reply #10January 01, 2010, 03:13:18 pm
Re: Anemic Audi!
« Reply #10 on: January 01, 2010, 03:13:18 pm »
josh (Powered by Spearco) has some 5000 piping and an intercooler i think, he might still want to get rid of it.
Reply #11January 01, 2010, 05:29:06 pm
colectb
  • 93
Re: Anemic Audi!
« Reply #11 on: January 01, 2010, 05:29:06 pm »
I have the Gasser intercooler already, I just need to pull the turbo off of the car to see if I can rotate it to the position its in on the gas cars. If I can it should be pretty straight-forward to hook up the stock piping, so maybe I'll see if he will want to part with just the piping. And there is an Audi dealer in Sioux Falls, I'll give them a call.
1986 Porsche 944 NA
Reply #12January 02, 2010, 07:14:03 am
TPW
  • 113
Re: Anemic Audi!
« Reply #12 on: January 02, 2010, 07:14:03 am »
You don't have to pull the turbo off to rotate it.  Just loosen the four 10mm bolts on the front and the discharge will move.  The only thing you have to watch is the connection to the wastegate control.  You don't want that to kink.
Reply #13January 02, 2010, 08:45:49 am
Re: Anemic Audi!
« Reply #13 on: January 02, 2010, 08:45:49 am »
his audi has a K24 on it. it doesnt have any wastegate control to kink. and it has 7 bolts holding the cold side on. i had to pull mine apart to get it to rotate, you might not have to.
Reply #14January 02, 2010, 09:27:29 am
TPW
  • 113
Re: Anemic Audi!
« Reply #14 on: January 02, 2010, 09:27:29 am »
I used to own that car, I know what the turbo looks like.
