Author Topic: New Pump Appears to have Stopped Pumping Fuel  (Read 17699 times)
Reply #60January 10, 2010, 03:00:16 pm
Mark(The Miser)UK
  • 1557
Re: New Pump Appears to have Stopped Pumping Fuel
« Reply #60 on: January 10, 2010, 03:00:16 pm »
Crazy......the belt would've had to be waaaay too tight to wear it that fast, I thought I read somewhere that a t-belt that much over tightened will just break? Or at least whine really loud.
Too bad though :'(
Yeah, kind of a sucky situation. All I can say is that it was tightened to the 45 degrees twist test, and I could go a little further.
Pretty frustrating, but it will get fixed.
Does the play in the shaft also allow you to lift upwards? It does seem strange that it only took 60 miles to wear that far. If however the bearing is slack all round , then belt tension is not the issue. A correctly tensioned belt may rely on the strength of the seal itself for a few miles before leaking... Perhaps :-\
Mark-The-Miser-UK
