Author Topic: Boost question on 1.9TD  (Read 3015 times)
October 18, 2005, 05:03:05 am
TD Passat
  • 29
« on: October 18, 2005, 05:03:05 am »
How can i go about turning the boost up more than 13psi? I am at the end of the actuator rod but i am looking to run 15-16psi. Any ideas or info on how to get more boost.
Apart from changing the actuator.
Craig
Tips and info required for tuning 94 Passat Turbo diesel.
Reply #1October 18, 2005, 05:10:15 am
Maarten
  • 339
« Reply #1 on: October 18, 2005, 05:10:15 am »
More fuel... more fuel results in more exhaustgasses that will spin the turbo :)
But beware of high exhaust temps and the stock turbo can't take much abuse (mine failed in a few weeks @1.2bar)
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #2October 18, 2005, 05:42:52 am
QuickTD
  • 1156
« Reply #2 on: October 18, 2005, 05:42:52 am »
Depending on your wastegate spring (they can vary a bit) you might also need to run a bleed or a "dawes device" type of boost controller to get the boost higher than stock.
Reply #3October 18, 2005, 06:10:36 am
Maarten
  • 339
« Reply #3 on: October 18, 2005, 06:10:36 am »
On my small turbo I disconnected the line to the wastegate to keep it shut, it ran 1.2bar max with some extra fuel.
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #4October 18, 2005, 06:39:04 am
TD Passat
  • 29
« Reply #4 on: October 18, 2005, 06:39:04 am »
Thanks for the replies!
Just serviced the Passat and ran some 10K Boost through it. Loads of smoke (build up ) and it feels smoother than before.
Craig
