Author Topic: passenger side engine mount Mk1 Rabbit  (Read 10013 times)
December 20, 2009, 04:41:28 pm
1.9TD Caddy
« on: December 20, 2009, 04:41:28 pm »
Hello all,
Got a question for all of you who have done a 1.6 N/A to a 1.9 AAZ swap in a MK1.
I managed to get the old engine mount out of my modified engine bracket.
The new engine mount bolt hole is not centered.
Here is a pic.
http://i580.photobucket.com/albums/ss245/AYANKAH/engine%20mount/th_enginemount006.jpg
I am coming up with four scenarios as to how it fits in the bracket
1.    http://i580.photobucket.com/albums/ss245/AYANKAH/engine%20mount/th_enginemount005.jpg
2.    http://i580.photobucket.com/albums/ss245/AYANKAH/engine%20mount/th_enginemount004.jpg
3.    http://i580.photobucket.com/albums/ss245/AYANKAH/engine%20mount/th_enginemount003.jpg
4.    http://i580.photobucket.com/albums/ss245/AYANKAH/engine%20mount/th_enginemount002.jpg
Can anyone tell be how it fits in the bracket?
I hate to hammer it in and find out its is 45deg out.
thanks!
Reply #1December 20, 2009, 05:06:50 pm
Re: passenger side engine mount Mk1 Rabbit
« Reply #1 on: December 20, 2009, 05:06:50 pm »
number 1, but just be sure i'd like to have someone confirm what i just said
Reply #2December 20, 2009, 09:01:01 pm
  • 2930
« Reply #2 on: December 20, 2009, 09:01:01 pm »
Number three is correct.
 "The upside down man"
Too bad you didn't get a heavy duty bushing,..
 yessiree I would have goten the heavy duty bushing.
Reply #3December 21, 2009, 05:45:15 am
1.9TD Caddy
« Reply #3 on: December 21, 2009, 05:45:15 am »
Heavy duty bushing? Do you know who sells it? and would you happen to have a P/N?
Thanks!
Reply #4December 21, 2009, 09:30:06 am
« Reply #4 on: December 21, 2009, 09:30:06 am »
i still say it is number one. he has the motor mount holder upside down in the picture. so by the orientantion of the holder itself, the rubber mount is correct in picture one.  but by the orientation of the just the rubber mount, then it is correct in picture 3.  but to make it easy, just remember that the bigger hole goes up towards the hood.
Reply #5December 21, 2009, 10:03:06 am
1.9TD Caddy
« Reply #5 on: December 21, 2009, 10:03:06 am »
Thanks for your help and patience guys but just to be sure I took another set of clearer pictures of the engine mount and bracket with the proper mount orientation.
so this is the correct orientation right??
http://i580.photobucket.com/albums/ss245/AYANKAH/engine%20mount/engmountorien001.jpg?t=1261418302
http://i580.photobucket.com/albums/ss245/AYANKAH/engine%20mount/engmountorien002.jpg?t=1261418550
Reply #6December 21, 2009, 05:55:57 pm
boxer246
  • 109
« Reply #6 on: December 21, 2009, 05:55:57 pm »
No, its not.  You have it 180 wrong.  Think of it this way....the weight of the motor should be "hanging" on more of the rubber "meat".  In other words, when on the car you should see more rubber on the topside than the bottom....over time the bolt hole will move upwards as the rubber breaks down.
Ash
'81 VW Caddy 1.6 now a TD
'88 Vanagon (building a AHU M-TDI)
Reply #7December 22, 2009, 08:35:28 am
« Reply #7 on: December 22, 2009, 08:35:28 am »
the mount is upside down in the picture
Reply #8December 22, 2009, 08:41:28 am
1.9TD Caddy
« Reply #8 on: December 22, 2009, 08:41:28 am »
Thanks guys! I will press it in 180 deg from what the picture shows!
Reply #9December 24, 2009, 02:57:48 am
Andy@React
« Reply #9 on: December 24, 2009, 02:57:48 am »
basically when it is on the motor, the hole should be low down
this is a pic of my downpipe, but you can see the mount!
Reply #10December 24, 2009, 08:33:53 am
1.9TD Caddy
« Reply #10 on: December 24, 2009, 08:33:53 am »
Thanks!
