Author Topic: piston protusion ?'s noobish  (Read 7993 times)
December 19, 2009, 09:09:44 pm
Possum79
  • 276
    • http://www.poscarclub.com
« on: December 19, 2009, 09:09:44 pm »
I have a pretty dumb question but I don't know the right answer. I have been in the process of taking my little 1.5 apart and just started to tear into the bottom end. I put cylinder 2 and 3 at tdc and i noticed that one cylinder is slightly lower then the other maybe by like 1/16". Is that normal? I was kinda rushed to leave and didnt really check it out. Is it just the operation of stroke its at? one on combustion one on exhaust or what ever?
1979 VW Rabbit Diesel L
Reply #1December 19, 2009, 09:19:35 pm
Re: piston protusion ?'s noobish
« Reply #1 on: December 19, 2009, 09:19:35 pm »
Due to machining differences it's normal for the piston protrusion to be slightly different across all 4 cylinders.
Having said that, if one is very obviously lots lower*and* there's signs of impact (impression of valves in the top of the piston (etc) it can signify a bent rod.
I don't think I've ever seen what the maximum allowable difference is... hopefully someone wise will weigh in.
Reply #2December 20, 2009, 11:18:26 am
« Reply #2 on: December 20, 2009, 11:18:26 am »
X2
and show us some pics that would be neat to see.
Reply #3December 20, 2009, 11:25:06 am
« Reply #3 on: December 20, 2009, 11:25:06 am »
I've heard the pistons are a matched set in order to have the same protrusion so it could be a piston out of another engine then.
Reply #4December 20, 2009, 12:51:19 pm
Possum79
  • 276
« Reply #4 on: December 20, 2009, 12:51:19 pm »
Ill try and get some measurements tonight along with pics. I mean I can visually see a difference and went wtf. I say 1/16" because I dont think I would notice anything smaller. This kinda sucks. I have no signs of piston contact. When I took the head apart I did find three broken lifters. When I rolled the bottom end over on my stand I saw some small chunks of metal bits fall out. Now this is really started to make me sad. :P
Reply #5December 20, 2009, 06:06:46 pm
« Reply #5 on: December 20, 2009, 06:06:46 pm »
Unfortunately broken lifters are a pretty reliable sign of valve-piston contact (and the resulting bent rods in some cases) but lets see what your measurements yield.  Pics of the top of the pistons would be great as well.
Reply #6December 21, 2009, 09:22:21 am
« Reply #6 on: December 21, 2009, 09:22:21 am »
1/16th inch? there has to be something bent or squished.
Reply #7December 21, 2009, 06:14:01 pm
maxfax
  • 2126
« Reply #7 on: December 21, 2009, 06:14:01 pm »
I can't say that I'm wise, but I've always been under the impression that the max allowed difference is the range given for choosing the HG thickness..  For example, a 3 notch HG is used for a piston protrusion of .033 - .036MM..   That seems like a rather small range, but then again it doesn't take much to make the compression uneven....
Reply #8December 21, 2009, 06:36:44 pm
Possum79
  • 276
« Reply #8 on: December 21, 2009, 06:36:44 pm »
SON OF A B WORD! After looking harder at the bottom side with the oil pan off it does look like a bent rod to my untrained eye. Anyways as far as measurements go I had piston #3 sitting .026" above the deck. And piston #2 was well over .035" under the deck. I gave up and cried a little inside. It looks like a bent rod and I did get pics but I dont think you can really see the bend. anyways here is the small size ones and Ill link to bigger ones if you want to take a better look. Im need of some new stuff here if anyone is feeling generous!  ;D
This was my problem cylinder too but I was getting coolant to flow into this and screw everything up. When I took the injectors out to compression test I had coolant fly out at me. I was gonna say no valve contact but I feel like an idiot. It probably hydrolocked on me and bent that rod. Still doesnt explain where the coolant came from.
« Last Edit: December 21, 2009, 06:53:59 pm by Possum79 »
Reply #9December 21, 2009, 07:42:47 pm
Possum79
  • 276
« Reply #9 on: December 21, 2009, 07:42:47 pm »
It makes sense though doesn't it? I had a problem of coolant getting in the cylinder and when I tried to compression test the thing I didnt take out all of the injectors at once just one at a time. And when I got to #2 I noticed coolant spraying me in the face. Hydrolocked with the injector still in there and bent the rod. If I would have taken all the injectors out at once I think I would have been in just for a resurface of the head. I cheaped out and didnt bother the first time to get the head checked out.
~Lessons learned.
Reply #10December 21, 2009, 08:20:45 pm
« Reply #10 on: December 21, 2009, 08:20:45 pm »
Correct me if I'm wrong but isn't the white blobs from coolant?
If it's for sure coolant then I'd say your hg went. :'( Possibly another rod is all you'll need.
Reply #11December 21, 2009, 08:24:12 pm
« Reply #11 on: December 21, 2009, 08:24:12 pm »
at least your block is vent free.
Reply #12December 21, 2009, 08:37:08 pm
Possum79
  • 276
« Reply #12 on: December 21, 2009, 08:37:08 pm »
I have had the head off the block for a while so its possible that its from taking the head off. I noticed some scrapes on the head when I took it off so I think thats where its leaking. I replaced the gasket a few months back and the one I took off wasnt broken at all other then being old and crusty. I replaced it with a new and it ran good for 5 minutes then I heard a cough and started to smoke and run like crap. When I took the head off this time I noticed the small scrapes but the gasket looked great.
Reply #13December 22, 2009, 09:58:25 am
« Reply #13 on: December 22, 2009, 09:58:25 am »
Which is why there's no valve impression marks... it all makes sense, unfortunately. :'(
Reply #14December 22, 2009, 11:44:07 am
« Reply #14 on: December 22, 2009, 11:44:07 am »
Yeah, I was wondering the same thing.
Until they actually open they're pressing against a virtually uncompromisable mass... so I can see it happening.
I'm thinking it would be exhaust lifters that would bear the brunt?
