Right....I'm almost at my wit's end with my van and was wondering if anyone had any ideas before I turn it into tinsel!!!!!!!
The van in question is a MK2 fitted with a GTD (SB) engine and box. The engine has had the boost pin mod, Guvnor mod, has 1.9 TDI injectors and is running just over 1bar of boost.
When driving it normally, the temperature gauge sits bang in the middle, the heater's nice and hot and everything's rosy.......then I put my foot down and feed in some boost and the temperature gauge starts climbing quickly, the heater goes cold and the water pressure goes through the roof!!!! It's blown 3 pipes so far!!!!!
But when I pull over and release the pressure through the cap, everything goes back to normal!!!!
It had a new waterpump and thermostat when I put the engine in about 3 months ago and all seemed fine until it blew the first hose and since then it hasn't been right! It's been a tw@t to bleed, so much so that I fitted a new radiator last week as that was in fairly poor condition, but everytime I try to bleed it, the bottom rad hose stays cold as if it's airlocked??
I finally decided to do a block test today, as I had come to the final conclusion that the extra boost had blown the Head Gasket, but that came back fine!!!!! So I am absolutely lost now!?!?!?!?!?!?
I know it's a bit long winded, but does anyone have any ideas pleeeeeeeeeeease??
Cheers
Jimmy
(profanity deleted by mod... no one is fooled by one *)
