Grounds grounds grounds grounds grounds.Did I mention grounds?!!! The running lights (which come on when you turn on the headlights) and turn signals are the same bulb with two filaments and a common ground. If that ground lifts very funny things happen.I'd be inclined to pull all 4 turnsignal/running light lenses and bulbs and clean everything up with fine sandpaper... looking for broken brown (ground) wires while you're at it.
