Author Topic: IP shaft play: how bad is bad?  (Read 1979 times)
December 18, 2009, 11:54:22 am
Wayland
  • 364
« on: December 18, 2009, 11:54:22 am »
Just pulled the pump off the 81 Jetta I just picked up. It's leaking out the CS lever shaft, so I was planning on resealing the whole pump, but I noticed the shaft has a fair bit of play (not sure how much, I didn't try to measure it) but it's definitely noticeable. The main shaft seal is not leaking, but I noticed the belt had been running off the outside of the pulley. Could this be caused by a worn bushing? I checked a few other pumps I have around, and they all seem to have play too, but maybe not as bad, so I'm wondering, how bad is bad?
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
Reply #1December 18, 2009, 01:33:48 pm
rallydiesel
  • 1880
Re: IP shaft play: how bad is bad?
« Reply #1 on: December 18, 2009, 01:33:48 pm »
There's a good thread on this with pics and specs if you search.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2December 18, 2009, 04:02:29 pm
« Reply #2 on: December 18, 2009, 04:02:29 pm »
I think that belts tend to try and run tighter, or to higher ground like Andrew said.
If the play is obviously noticeable it's probably worn out.
