China made parts
Topic: China made parts (Read 2731 times)
December 16, 2009, 01:00:31 pm
rodpaslow
China made parts
December 16, 2009, 01:00:31 pm »
I bought a new head off ebay thinking it was German, and I get it home and it's made in China and not near the casting quality of my TD head. Has anyone used these chineese parts and had much luck with them. I'm thinking I need to re-do my original TD head best I can and re-use it. Past life I worked in a Steel foundry and not impressed! (I know were probably getting a large amount of part that are made their instead of NA)
December 16, 2009, 01:04:36 pm
Re: China made parts
December 16, 2009, 01:04:36 pm »
Some on here have ran those chinese heads with boost and they seem to hold up.
December 16, 2009, 02:28:21 pm
GEE-BEE
December 16, 2009, 02:28:21 pm »
I wouldnt touch them....
I found a brand new German AAZ head assy ( complete with valves etc )with new valve cover for 350.00
Frht was 64.00 euro ( DHL )
Try: ebaygermany
You get what you pay for !
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
December 16, 2009, 04:17:42 pm
December 16, 2009, 04:17:42 pm »
I'd get a used head over a new Chinese one any day. That being said if a Chinese head was my only option I would not hesitate to install it. I'd be worried as all heck but it's better then scraping the car.
December 17, 2009, 04:24:45 am
TurboJ
December 17, 2009, 04:24:45 am »
Can anybody tell me how to spot a Chinese head?
There are so many head manufacturers in Europe alone, and I'm not even sure which manufacturers
are
European...
Maybe someone can provide us with a list of the reputable manufacturers?
Jetta II 1.6 TD 'Project 200'
December 17, 2009, 09:48:05 am
wil892
December 17, 2009, 09:48:05 am »
I have run my head which is a chinese casting but with new oem parts for 10,000 miles. touch wood it seems absolutely fine. this is on a stock 80hp SB GTD engine. yes the casting didnt look as well finished as the german one, and obviousely i would have fitted german if I could but didnt have time to find one (or money)
Will
1991 Golf MK2 GTD
December 18, 2009, 11:38:15 am
December 18, 2009, 11:38:15 am »
I'm with Burn..
If I HAD to I would run one or, if I was just screwing around and didn't want to look for a German head then sure. If it was my daily driver and I had a choice I would run German..
China made parts
