Author Topic: Injector lines - how do you torque them?  (Read 5228 times)
December 14, 2009, 01:53:41 am
benzwagon
  • 25
« on: December 14, 2009, 01:53:41 am »
How do you guys torque the lines between injector pump and injectors? Crows feet? I know I have seen a 'line socket' (is there a real name?) but I am having a hell of a time tracking one down.
Reply #1December 14, 2009, 02:00:37 am
Re: Injector lines - how do you torque them?
« Reply #1 on: December 14, 2009, 02:00:37 am »
With an end wrench :D
18 ft lb, so not real tight, and if it leaks, go just a hair more.
Reply #2December 14, 2009, 02:40:33 am
anto
« Reply #2 on: December 14, 2009, 02:40:33 am »
I do them with an open ended spanner, they arent overly tight so dont need anthing else.
You could use a pipe spanner(use it for brake pipes etc) if you were scared of rounding them off if they were very tight.
Reply #3December 14, 2009, 10:45:05 am
Op-Ivy
  • 513
« Reply #3 on: December 14, 2009, 10:45:05 am »
Wrench works great! 17mm IIRC.
Reply #4December 15, 2009, 01:25:58 am
benzwagon
  • 25
« Reply #4 on: December 15, 2009, 01:25:58 am »
sorry guys im a dummy...
thought i was reading they needed to be torqued to fifty whatever the injectors are....
car is up and running. super excited.
