Author Topic: Tranny question.  (Read 1986 times)
December 10, 2009, 05:34:47 pm
kaneb
  • 164
    • www.dasdubbers.org
Tranny question.
« on: December 10, 2009, 05:34:47 pm »
I have an 83 rabbit diesel LS came with a 1.6NA and a 5speed transmission.  Im not sure the code of the tranny, but im rebuilding a 1.6TD MF engine and it will have more power then stock. Im just curious would a transmission out of say a mk2 diesel be better for this engine, or will be pretty close to the rabbits as far as gear ratio?  I believe they are both 020's. I am also planning on going with a 8v clutch and 16v pressure plate.
Thoughts?  Or maybe another transmission recomendation?
Tia,
Kane
2004 Tdi sport-daily
1983 Rabbit TD-go kart
www.dasdubbers.org
Reply #1December 10, 2009, 05:37:18 pm
Re: Tranny question.
« Reply #1 on: December 10, 2009, 05:37:18 pm »
figure out the codes and look up the ratios. that will tell you a better story, a newer tranny may not be better. my trans that im running now is out of an 86 gas jetta. nice high .75 fifth gear and 3.67 final drive.
Reply #2December 10, 2009, 07:10:45 pm
GEE-BEE
  • 1604
« Reply #2 on: December 10, 2009, 07:10:45 pm »
Mine  is a O20 ChD .074 with a 3.66 Final
There is a code FF on ebay cheap, 100 mm flanges
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #3December 12, 2009, 07:59:59 am
« Reply #3 on: December 12, 2009, 07:59:59 am »
how do you have .74 and 3.66? i thouhgt that vw did .75 and .71 over drive. and some had .68 if i remember right.
