Author Topic: 1.5L pump on 1.6L  (Read 7650 times)
December 07, 2009, 01:39:46 pm
dh13
  • 108
1.5L pump on 1.6L
« on: December 07, 2009, 01:39:46 pm »
So I just bought a 1980 diesel Rabbit pickup. The lady I bought it from said it was a 1.5 but in fact it is a 1.6. I confirmed this when I looked at the casting on the back of the block "1.6L."
So I replaced the headgasket and timing belt and other misc. parts. I was planning on turboing it so I have been trying to find as much information as I can and have found something that makes me wonder.
First off when I was timing it I looked in my Bentley an saw that there was pump timing for a "yellow dot" pump which meant nothing to me because I am after all new to this whole Volkswagen thing.  :-[ . But I timed it and got it all running and everything has been good. I had a leak in the injector pump so I pulled the top cover off to fix it. While I was at it I decided to do the gov. mod. I had read all the gov. mod threads, and when I tore into my pump what I found inside looked nothing like what I had seen.
Today I started looking to see if I could find out what pump I had to make sure I didn't have a yellow dot or something that I had missed. Come to find out the pump is a 1.5L yellow dot pump from what I have read. I assume that when the 1.6L block was swapped in they decided to use the 1.5L pump.
My concern is that when I turbo it I will not be able to run enough fuel. I have the pump turned all the way up as it is. I had the smoke screw turned up more yesterday and the idle hung, so I turned it back down.
Here are some pictures.
From what i have read the yellow dot pump has just an "A" at the end of the part number
This is a picture of where the "yellow dot" might have been
I know my post might now make much sense but I am just trying to figure out if in fact I have a 1.5L pump. If I do I will just find a turbo pump and call it good. I know one of my friends has one and I have one in my shop but it is on a turbo motor that I don't really want to tear apart.
1991 Jetta 1.6TD
1980 Caddy 1.6TD
Reply #1December 07, 2009, 03:00:08 pm
rallydiesel
  • 1880
Re: 1.5L pump on 1.6L
« Reply #1 on: December 07, 2009, 03:00:08 pm »
Quick google search with those part #'s shows its a 1.6 pump.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2December 07, 2009, 05:14:54 pm
dh13
  • 108
« Reply #2 on: December 07, 2009, 05:14:54 pm »
according to this site http://www.mwfi.com/dieselPage/VW_Diesel_Parts.htm
its is a
Volkswagen diesel Injection pump for 1977-80
Manual Transmission 1.5 diesel (non-turbo) Rabbit or Dasher (OEM # : 068 130 107A)
1991 Jetta 1.6TD
1980 Caddy 1.6TD
Reply #3December 07, 2009, 05:28:51 pm
dh13
  • 108
« Reply #3 on: December 07, 2009, 05:28:51 pm »
Although on oregon fuel injections website it says that it is a
Rebuilt Injection Pump Volkswagen Rabbit, Rabbit Pickup, Jetta 1.6L 1977, 1978, 1979 VW # 068130107A, 0460494005
I never thought of it that way but I was mainly concerned about the injector pump.
I know for sure it is a 1.6 block and head. Its is a 12mm block and head.
1991 Jetta 1.6TD
1980 Caddy 1.6TD
Reply #4December 08, 2009, 03:02:19 am
RustyCaddy
  • 395
« Reply #4 on: December 08, 2009, 03:02:19 am »
107A's can be either yellow dot pumps or non yellow dot
if you time a yellow dot pump as a non yellow dot pump (0.033 - 0.0.39 mm) it will hardly idle so it is pretty easy to tell which pump you have which that way (assuming the pump was running before you retimed it).
i run a 107a on a 12mm mechanical block and it does pretty well but the guy at Oregon fuel injection in Medford thought it may tend to run little lean for a 1.6 liter.
Reply #5December 08, 2009, 06:53:02 am
dh13
  • 108
« Reply #5 on: December 08, 2009, 06:53:02 am »
It was running before I tore into it to replace the HG.
I timed the pump to 1.00mm and it seems to be fine.
I timed it using the specs from the Bentley
Early Chassis:  (1977-1983)
1.5l non-turbo 1977-1980                                        0.88 +/- 0.05 mm
1.5l non-turbo 1980 with yellow dot                         1.15 +/- 0.05 mm
1.6l non-turbo  1981, 1982, and 1983 pickup            0.88 +/- 0.05 mm
1.6l non-turbo  1983 Rabbit and Jetta                        0.95 +/- 0.05 mm
1.6l non-turbo  1983 Vanagon                                  0.90 +/- 0.05 mm
1.6l tubo diesel (1982-1983)                                       1.00 +/- 0.05 mm
I did not time it as a yellow pump because at that time I didn't know what that meant. I have a feeling I will be changing the pump so I guess this is a non-issue now..
1991 Jetta 1.6TD
1980 Caddy 1.6TD
Reply #6December 08, 2009, 06:22:51 pm
RustyCaddy
  • 395
« Reply #6 on: December 08, 2009, 06:22:51 pm »
Thanks...my bad, it should have read 0.033-0.039in not 0.033-0.039mm
