Author Topic: Return spring?  (Read 2053 times)
December 06, 2009, 08:39:42 pm
Return spring?
« on: December 06, 2009, 08:39:42 pm »
The one labeled "return spring " in this picture;
My pump doesn't seem to have it.
i know it's been opend before, as there are no safety wires anywhere.
I know it was running because the donor car had Tbelt failure, and broken cam.
Do I need it?
Doesn't look like Cummins thinks so...
What do you think? Or better, do you know for sure?
Pump # is 460 406 044, Volvo D24T
« Last Edit: December 06, 2009, 08:45:44 pm by 745 turbogreasel »
Reply #1December 06, 2009, 08:41:41 pm
Re: Return spring?
« Reply #1 on: December 06, 2009, 08:41:41 pm »
Pretty sure that's the fast-idle spring, on pumps so equipped.
If your particular pump doesn't have the fast idle lever you don't have it, or need it.  ;)
Reply #2December 06, 2009, 08:48:59 pm
Re: Return spring?
« Reply #2 on: December 06, 2009, 08:48:59 pm »
Good news :D
My car uses a water operated  bit of junk  to seize up and not deliver fast idle by not moving the external throttle arm.
