Author Topic: 5 pot TDI?  (Read 24503 times)
Reply #30December 10, 2009, 06:23:07 pm
oldskool rich
  • 446
Re: 5 pot TDI?
« Reply #30 on: December 10, 2009, 06:23:07 pm »
thats right.
most audi boxes are both, but not all
you can fit an A6 TDI quattro box to any TDI/IDI i checked this therory at work the other wk
im using sutch an application in my caddy, you can pare this up with the old locking diffs and hav sum fun
f6squared I.D.S.T
Reply #31December 11, 2009, 01:29:10 pm
VWSmokr
  • 39
Re: 5 pot TDI?
« Reply #31 on: December 11, 2009, 01:29:10 pm »
Cool. When the time/money mix is right, I'd like to get an Audi V6 TDI for one of my VW campers, for more grunt & less fuel consumption. KEP has the adapters for VW or Porsche trannies. Gotta finish the German V6 gasser conversion on the other camper first. ::)
Thanks for the info.
J.R.
SoCal
J.R.
SoCal
Reply #32December 11, 2009, 06:31:12 pm
Pat Dolan
  • 163
Re: 5 pot TDI?
« Reply #32 on: December 11, 2009, 06:31:12 pm »
Smokr:
You might want to re-consider that.  The 2.5 V6 is VERY heavy, whereas the 5 banger is reasonably light.  The 2.5 can use all of the hardware from RSA that bolts in the 2.6 gasser, includng hyrdaulically dampened mounts.  We had the same thought as you, but after a lot of consideration, went with the 5 cyl instead (and had Giles build a nice MTDI pump for it to keep the installation all mechanical).
lifetime VW enthusiast, racer, fixer, addict, etc.
'03 TDI Variant, MkII Golf Country, Mk1 and II Scirocco (gassers), a Vanagon aircooled, an Audi 2.0 TD waiting to become a Porsche TD (in my M471 924), FLD120/DDEC IV, Ford 7.3/450, Iveco D220 and some 6D14T Mitsus and a few more.
Reply #33December 12, 2009, 03:29:51 am
blackdogvan
  • 574
Re: 5 pot TDI?
« Reply #33 on: December 12, 2009, 03:29:51 am »
I've always wanted to see a 2.5 v6 mtdi using a cummins 12mm pump. From what i can see it would bolt in no problem! Those pumps are dime a dozen around here.
1991 Vanagon 1.9 mTDI
Reply #34December 12, 2009, 07:14:52 am
CdnVWJunkie
  • 309
Re: 5 pot TDI?
« Reply #34 on: December 12, 2009, 07:14:52 am »
Black dog, I presume you mean the VE 6BT CTD pump?  That certainly would make for an interesting conversion.  Lots of info out there on the 6BT pumps some making huge power.
Reply #35December 12, 2009, 05:59:48 pm
oldskool rich
  • 446
Re: 5 pot TDI?
« Reply #35 on: December 12, 2009, 05:59:48 pm »
the V6 is a crap engine, the heads always go wrong and there a bastard to work on, also weight is a massive issue too, they do bout 30 MPG pretty *** for a diesel , ive been getting 50 out my 5 pot you may as well stick with petrol
how much does giles charge for a 5pot injection pump?
please can sumone tell me how to contact him?
f6squared I.D.S.T
Reply #36December 12, 2009, 06:07:40 pm
Re: 5 pot TDI?
« Reply #36 on: December 12, 2009, 06:07:40 pm »
Vendors section of this forum. If you send him a pump drain all the diesel out before shipping...ask me how I know  :-[
Reply #37December 13, 2009, 08:24:24 am
Re: 5 pot TDI?
« Reply #37 on: December 13, 2009, 08:24:24 am »
Why not give you the info...I have time now :D
http://www.vwdiesel.net/forum/index.php?topic=3100.0
Reply #38December 13, 2009, 12:23:07 pm
55eta
Re: 5 pot TDI?
« Reply #38 on: December 13, 2009, 12:23:07 pm »
you could also look at the merc sprinter 2.9 tdi the early ones are mechanical ve pumps and 5cylinder but are chain driven so it would depend on whether you could swap shafts or fit your pulley some how
Reply #39December 14, 2009, 02:37:05 pm
oldskool rich
  • 446
Re: 5 pot TDI?
« Reply #39 on: December 14, 2009, 02:37:05 pm »
oooo, i like the sound of a merc pump, tell me more, whats it off?
i know some very impressive machinists that can make anything happen
f6squared I.D.S.T
Reply #40December 14, 2009, 03:21:26 pm
diesel205
  • 1
Re: 5 pot TDI?
« Reply #40 on: December 14, 2009, 03:21:26 pm »
is this a straight swap, besides the pulleys? I have audi 100 C3 2.0td 5cyl, the engine is broken , so id like to replace it with  2.5 tdi 5 cyl but without ecu. I have read the faq about m-tdi pumps , but most of the information is about 1.9 tdi. Is it possible to build a franken pump using my  2.0 td pump and 2.5 tdi pump or are there some factory meh tdi pump which could be used.
Reply #41December 14, 2009, 05:31:44 pm
55eta
Re: 5 pot TDI?
« Reply #41 on: December 14, 2009, 05:31:44 pm »
forget about the merc pumps as they are e tdi on the sprinters i  got them mixed up with the 2.9 idi,s ??? as used on the merc 600 series vans but by the sound of it the audi 100 2.0-2.5 tds sound a good bet but probably like rocking horse sh#t over here also vw lt2.5 N/a engine is 5cyl but i am not shore if it is electronically controlled like the sdi,s
« Last Edit: December 14, 2009, 05:44:19 pm by 55eta »
Reply #42December 22, 2009, 04:46:59 pm
oldskool rich
  • 446
Re: 5 pot TDI?
« Reply #42 on: December 22, 2009, 04:46:59 pm »
ok bit scared that the injection pump will cost me the same as the whole car  :o
apparently will need to run 60psi to get anywhere near 300bhp
according to my mate that tunes MR2s PSI meens nothing and its all about air flow, which i strugle to get my head around but its been tried and tested according to him, so im looking at the holset HX40 because its massive. anyone got any thorts on the matter? will that be too laggy? so many people telling me different things its hurting my head
fitted my S line interior, its starting to look like a half desent car, getting big brake conversion after xmas  ;D
any more info on pumps and how to covert them to MTDI will be grately appreciated
no disrespect to giles and im sure hes worth it but i just dont think i can afford it  :'(
f6squared I.D.S.T
Reply #43December 22, 2009, 06:09:28 pm
Re: 5 pot TDI?
« Reply #43 on: December 22, 2009, 06:09:28 pm »
He is correct. Pressure is restriction to flow.
If you are running 15 psi on a stock head it will flow say 150 CFM
If you port that same head and run the same 15 PSI you will now be flowing 200 CFM because there is less restriction.
Make sense? I just made those numbers up by the way.
Reply #44December 23, 2009, 12:33:10 am
MJF
  • 581
Re: 5 pot TDI?
« Reply #44 on: December 23, 2009, 12:33:10 am »
Where did you get that 60psi? Boost doesnt make power, itīs the flow like your mate said. HX40 is "a bit" overkill for these engines, fine up to 500+hp in di engine. HE221W @27psi made 280hp and thats pretty much what you can get with 11mm pump and stock head.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
