Author Topic: 5 pot TDI?  (Read 23545 times)
Reply #15December 07, 2009, 03:58:38 am
gigaz2
  • 626
Re: 5 pot TDI?
« Reply #15 on: December 07, 2009, 03:58:38 am »
there is also a truck nozzle, .290 5 hole with just about the same spray angle, has anybody tried something that big? they are cheap as well
not sure on the spray orientation
Reply #16December 07, 2009, 07:06:28 am
Re: 5 pot TDI?
« Reply #16 on: December 07, 2009, 07:06:28 am »
Where did you find this information?
Reply #17December 07, 2009, 10:00:21 am
aidan
Re: 5 pot TDI?
« Reply #17 on: December 07, 2009, 10:00:21 am »
Thats a good price for those r520, cheapest i've seen is £220 for 4.
What vehicles (machinery?) used Holset?
Rich, i've just removed the engine from my mk3, I have the complete loom and a chipped/de-immo ecu, but fancy going to mtdi in a mk2 - this depends heavily on work situation though
Reply #18December 07, 2009, 12:32:25 pm
gigaz2
  • 626
Re: 5 pot TDI?
« Reply #18 on: December 07, 2009, 12:32:25 pm »
from the manufacturer, Renault injectors  ;D
Reply #19December 07, 2009, 12:34:57 pm
oldskool rich
  • 446
Re: 5 pot TDI?
« Reply #19 on: December 07, 2009, 12:34:57 pm »
MTDI is easy if sumone has cracked the dico pump problems
heard sumone saying it was a bit flat?
found a 5pot TD pump but i will surely need to change to the TDI cam plate? and what about the advance? what do i need to do? is it gona be a mission of trial and error like changing the AAZ pump into an MTDI?
anyone know of a cheap turbo nocking about? is my supercharger out of the question?
realy want giles to do all the headache work, but i haventy got that much money, id have to sell my kidneys unless i can pay him in parts
f6squared I.D.S.T
Reply #20December 07, 2009, 06:35:39 pm
Re: 5 pot TDI?
« Reply #20 on: December 07, 2009, 06:35:39 pm »
It doesn't hurt to ask. He's done it before and I know he wants a K14 off a 5 cylinder :)
Reply #21December 08, 2009, 04:46:56 am
gigaz2
  • 626
Re: 5 pot TDI?
« Reply #21 on: December 08, 2009, 04:46:56 am »
I have an exhaust scroll from one of those, just the cast part and wastegate attached
Reply #22December 08, 2009, 11:39:18 am
oldskool rich
  • 446
Re: 5 pot TDI?
« Reply #22 on: December 08, 2009, 11:39:18 am »
 ;D thats funny cus ive got a mint turbo with everything apart from the exhaust scroll sitting in my garage
anyone know how i can contact him?
ive decided today that theres no point in doing this A6 up, im gona buy a A6 quattro so i can do it properly
ive found some cheap leather interior and good set of coilovers, i think im gona go all out
f6squared I.D.S.T
Reply #23December 08, 2009, 11:42:28 am
aidan
Re: 5 pot TDI?
« Reply #23 on: December 08, 2009, 11:42:28 am »
rich I have a complete k14 if interested in a mtdi part swap stylee! needs rebuild so cheap cheap (turbine housing all good)
Reply #24December 08, 2009, 02:51:38 pm
gigaz2
  • 626
Re: 5 pot TDI?
« Reply #24 on: December 08, 2009, 02:51:38 pm »
lets trade the scroll for the IP bracket with the 68mm hole, what do you say?
I'll take a few pictures and send you a pm asap
Reply #25December 08, 2009, 02:57:03 pm
gigaz2
  • 626
Re: 5 pot TDI?
« Reply #25 on: December 08, 2009, 02:57:03 pm »
http://www.midlandturbo.com/index2.php?search=AUDI
it seems there were two flavours of AATs until 94 they used k16 after that k14, I think mine is the one of the first ones
Reply #26December 08, 2009, 05:57:10 pm
oldskool rich
  • 446
Re: 5 pot TDI?
« Reply #26 on: December 08, 2009, 05:57:10 pm »
the turbo isnt even off my car but its defo 5 pot aplication just had it lying around
 :D i dont even want a turbo i just want sumthin to bargain with giles to get a free/cheap pump
you realy that despirate for a bracket? dont you live in portugal? do they not have machinists down ur way? a mate of mine just got his machined, only cost him a tenner
if your realy stuck i could sort you out with one, but prepare to get bummed on the postage
i need to speek to this giles fella before i start swapsies, i must have sumthin he needs
what MTDI stuff are people after?
ive got a 1Z thats finished with ARPs, 6 point injectors and disco pump, mint ring gaps and bearings
adjustable pully all custom made to fit, also 11mm PP and better cam plate. ive not had the chance to put it in a car yet but just needs a turbo and it should fly
i cant see me using it now so if anyone wants it, offers around 650
if you want bits ive got loads of stuff
f6squared I.D.S.T
Reply #27December 09, 2009, 02:20:56 am
gigaz2
  • 626
Re: 5 pot TDI?
« Reply #27 on: December 09, 2009, 02:20:56 am »
damn, I forgot about postage, yap it would probably cost more shipping than the parts value due to weight.
I have a good machinist, he even throws a few freebies now and then, but takes ages to get things done, must get a mini lathe for myself  ;D
Reply #28December 09, 2009, 05:03:17 pm
VWSmokr
  • 39
Re: 5 pot TDI?
« Reply #28 on: December 09, 2009, 05:03:17 pm »
Not to get off-topic, but do the inline 5-cyl Audi and the V6 Audi engines bolt up to the same transaxles, ie. same bellhousing patterns? TIA
J.R.
SoCal
J.R.
SoCal
Reply #29December 10, 2009, 02:26:57 pm
gigaz2
  • 626
Re: 5 pot TDI?
« Reply #29 on: December 10, 2009, 02:26:57 pm »
yap, there are three main bolt patterns in DUBs, the 827 4 cyl , the vr6 and the 5 and 6 cylinder engines, audi often uses a bellhousing that accepts both 4cyl and 5/6cyl
anyway, this is what I remember from searching a while ago
