S-PAutomotive.com
Author Topic: GOVERNOR MOD  (Read 26963 times)
Reply #45February 20, 2010, 11:04:41 pm
kaneb
  • 164
    • www.dasdubbers.org
Re: GOVERNOR MOD
« Reply #45 on: February 20, 2010, 11:04:41 pm »
Was easy to do.  Was planning on waiting till the engine was in the car. Then decided when cleaning up the pump i would just do it today.  Didn't use a new seal mine should be fine, if it leaks then ill get the new seal kit.
2004 Tdi sport-daily
1983 Rabbit TD-go kart
www.dasdubbers.org
Reply #46March 02, 2010, 06:23:56 pm
professor
  • 14
Re: GOVERNOR MOD
« Reply #46 on: March 02, 2010, 06:23:56 pm »
i guess it wouldnt be a huge job to wire a relay into the stop solenoid, trigerred by an electronic overspeed signal (either from tach or something else). cut fuel at specific rpm.....
how do we do that? anyone do this? anyone have an electric scheme of that?
thks
let me think on it a while, i'll get back to you :-)
hi
don't forget this ;D
thanks
Reply #47March 02, 2010, 09:40:31 pm
  • 2736
Re: GOVERNOR MOD
« Reply #47 on: March 02, 2010, 09:40:31 pm »
I removed the smaller spring and put a 1/16" thick washer in it's place.
 the governor still works and the power through the midrange and upper end increased.
Tornado red, '91 Golf 4 door,
Reply #48March 02, 2010, 09:42:02 pm
Re: GOVERNOR MOD
« Reply #48 on: March 02, 2010, 09:42:02 pm »
I can't wait to do this mod! IT IS GETTING CLOSE TO THAT TIME :)
I think I will shim about.. as much as I can. or maybe be conservative?
Has anyone tried small shim and then went more shim? was there any increase in power? butt dyno readouts? increase in smoke? EGT's?
Reply #49March 03, 2010, 06:53:22 pm
Re: GOVERNOR MOD
« Reply #49 on: March 03, 2010, 06:53:22 pm »
I usually replace the main spring with a solid piece of tubing and leave the intermediate alone.
Runs great, no de-fueling at all..
I've built a pump or two just for reference..   8)
