Author Topic: squirter screws  (Read 1960 times)
December 02, 2009, 09:21:03 pm
moTthediesel
  • 194
squirter screws
« on: December 02, 2009, 09:21:03 pm »
Ever wonder why they used those little Torx screws to hold the piston squirters into the block? I removed them from the block I was working on so I could deglaze the cylinders for new rings. One of the screws had it's drive socket damaged and I had a very hard time getting it out. I replaced all four with short Allen socket head screws and started putting the bottom end back together. All seemed well until I bolted the first rod big end to the crank.
You know that magic moment when you first roll the flywheel over and you see that piston slide smoothly up and down in it's cylinder? Well, what you don't want to happen is for the rod to go "BONK" and stop part way around -- but of course in this case that is exactly what happened. Sure enough, the head end of the rod bolt was hitting the head of the squirter screw.
I don't know where to find one of those little Torx screws, so I guess I'll chuck the Allen heads in an electric drill and put them against a bench grinder wheel to reduce the head to a lower more mushroom shape. Maybe there was some reason why they used those little screws after all  ::)
'82 LandCruiser Diesel Conversion
4Cylinder 3B/KKKturbo/AudiIntercooler(gone, BNF)
'92 Dodge/Cummins D350 Getrag Dually
356 w/Quantum 1.6TD (73 mpg!)
'85 BMW 524td (Der Komisar)
'00 Jetta TDI 5spd
Reply #1December 03, 2009, 05:31:51 am
dod996
  • 5
Re: squirter screws
« Reply #1 on: December 03, 2009, 05:31:51 am »
Buy the size you need in a button head style from McMaster-Carr
Reply #2December 03, 2009, 05:33:20 am
dennis
  • 311
Re: squirter screws
« Reply #2 on: December 03, 2009, 05:33:20 am »
Good thing you found out. If you have ever worked on Type I Beetle Autosticks and have seen the aftermath of incorrect torque coverter bolts you start to appreciate the engineering of the original hardware.
1980 Caddy TD (Always in progress)
1983 Volvo 245 D24 NA Building D24T
1980 Air-cooled Westy
1956 F100 (What to do???))
