Author Topic: AAZ Silicone Engine Coolant Hose Assys  (Read 9030 times)
Reply #15December 03, 2009, 09:05:35 pm
Syncroincity
  • 727
Re: AAZ Silicone Engine Coolant Hose Assys
« Reply #15 on: December 03, 2009, 09:05:35 pm »
Are the originals destroyed in the process? Not that it really matters since I'd be using the silicone hoses... ;)
These are quite a bit more complicated than the MK1 or AAZ engine hoses;
Any idea on costs per set on a 25+ run?
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #16December 03, 2009, 10:52:30 pm
GEE-BEE
  • 1604
« Reply #16 on: December 03, 2009, 10:52:30 pm »
I would est  275.00 / 325.00, NO TOOLING CHARGE
Those aren't easy to make with the Union's
FOUR COLORS: BLACK, RED, YELLOW,BLUE
ALL TUV CERTIFIED
Send them and they will be returned
GEE-BEE
[email protected]
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #17December 04, 2009, 06:55:06 pm
sawedoffgolf
  • 213
« Reply #17 on: December 04, 2009, 06:55:06 pm »
I'd be interested in 2 sets for a mk1, (gasser and a diesel)
any pics of a set yet?
Reply #18December 04, 2009, 07:07:04 pm
GEE-BEE
  • 1604
« Reply #18 on: December 04, 2009, 07:07:04 pm »
Iam going to need a 8v and 1.6 Diesel original set, the samco stuff is based on european model and doesnt fit
I think that the upper and lower 8v and diesel radiator hoses are the same ( 2 )
1each,same with coolant resv tank hose
2each ,Hoses from firewall to heater core ( straight hose )
2each,to bypass valve and return firewall to engine ( straight to 90's )
It's all the lower 8v that is different to the 8v
Gee-Bee
Iam moving forward with this and would like to thank all the help from members here
AAZ Engine
MK III BODY
Mk1 8V ( Caddy and 1.6 n/a diesel )
Giles Pump OHC
MK1 JETTA DASH
Reply #19December 05, 2009, 02:42:57 am
sawedoffgolf
  • 213
« Reply #19 on: December 05, 2009, 02:42:57 am »
Gee-Bee
AAZ Engine
MK III BODY
I have a mk1 with AAZ and a mk1 with G60. all the hoses are exactly the same.
Reply #20December 05, 2009, 08:41:59 am
GEE-BEE
  • 1604
« Reply #20 on: December 05, 2009, 08:41:59 am »
SO THE G60 AND THE AA BOTH USE THE SAME HOSES ON THE ENGINE ?
NOT THE ONES CONNECTING TO THE BODY ..
LET ME KNOW
THANX GB
Giles Pump OHC
MK1 JETTA DASH
Reply #21December 05, 2009, 02:44:20 pm
sawedoffgolf
  • 213
« Reply #21 on: December 05, 2009, 02:44:20 pm »
I am pretty sure they are the same, i will double check later today.
Reply #22December 06, 2009, 08:22:59 am
GEE-BEE
  • 1604
« Reply #22 on: December 06, 2009, 08:22:59 am »
I can email you a g60 pic, email me at [email protected]
Giles Pump OHC
MK1 JETTA DASH
