Author Topic: Installing power steering on an economy AAZ?  (Read 6404 times)
Reply #15December 02, 2009, 09:10:33 am
Tag-Along
  • 25
Re: Installing power steering on an economy AAZ?
« Reply #15 on: December 02, 2009, 09:10:33 am »
OK...cool.  I will have to check into that.
See I didn't realize that a manual steering setup was different then a power steering setup that's not working. I figured the amount of effort to steer both would be the same.  So, you guys are telling me that with a manual rack it should be easier then steering a power steering equipped vehicle with it not working? ...if that makes any sense  :)
Reply #16December 02, 2009, 09:13:07 am
truckinwagen
  • 1895
« Reply #16 on: December 02, 2009, 09:13:07 am »
yep, the manual rack takes more turns lock to lock.
this difference in gearing makes it easier to turn without the help of the hydraulic pressure of the PS
83 Opel Kadett Diesel
Reply #17December 02, 2009, 09:16:25 am
Tag-Along
  • 25
« Reply #17 on: December 02, 2009, 09:16:25 am »
Ok...now I feel stupid   ::):P
I didn't realize that the steering racks were different. I always thought that both manual and power steering had the same set up minus the pump, accesories, etc.
See NOW it's making more sense why people are telling me to just go w/o the power steering!
Keep it coming guys...and gals
Reply #18December 02, 2009, 09:19:17 am
truckinwagen
  • 1895
« Reply #18 on: December 02, 2009, 09:19:17 am »
just make sure the rack you get has good bushings in it.
the bushings are hard to get and very expensive, it is almost cheaper, and much easier to buy a brand new rack than locate and install new bushings.
and a rock with bad bushings is a pain in the ass(ask me how I know)
Of course this applies to both manual and power racks, but I thought I would pass it along.
Reply #19December 02, 2009, 09:20:36 am
Tag-Along
  • 25
« Reply #19 on: December 02, 2009, 09:20:36 am »
Yea I would probably just get a new rack...just to be on the safe side.
Thanks guys!
Reply #20December 02, 2009, 11:00:34 am
GEE-BEE
  • 1604
« Reply #20 on: December 02, 2009, 11:00:34 am »
Meyle is a oem Mfg
Check your steering boot"s/ u-joint boot
Ben at MK1 Autohaus has them new in stock along with the boot's
Rabbitparts.com
rack 135.00
boots 12.00 set
Tie rod assy 25.00
no u-joint boot on there site
I did all new item's up front along with Weitec coilovers and addco sway bar set and nuespeed upper strut bar
Hope this help's
Gee-Bee
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #21December 02, 2009, 12:08:18 pm
« Reply #21 on: December 02, 2009, 12:08:18 pm »
The manual rack has a tighter turning radius though
Reply #22December 02, 2009, 01:04:27 pm
GEE-BEE
  • 1604
« Reply #22 on: December 02, 2009, 01:04:27 pm »
I love tight rack's , those loose ones are floopy and bounce on potholes when I drive... ;)
Gee-Bee
Giles Pump OHC
MK1 JETTA DASH
Reply #23December 02, 2009, 02:13:18 pm
spencebm
  • 686
« Reply #23 on: December 02, 2009, 02:13:18 pm »
another one saved from power steering woes!  This made my day.
Ben Spencer
Reply #24December 02, 2009, 02:41:21 pm
jack's lack
  • 275
« Reply #24 on: December 02, 2009, 02:41:21 pm »
The big snafu that no one has mentioned it that the U-joint shaft that connects the steering column to the rack is different between the power and manual versions. The manual is longer and the online parts houses rarely if ever have them. it is a junkyard or samba part. So figure out which one you have first. Don't ask me how I know ;)
1982 Rabbit diesel L 4 door
AAZ, K14, Giles pump, PD150 intake, P&P'd head, ceramic coated pistons, 2.5" stainless down pipe & exhaust. FK coils
My Build Thread
Reply #25December 03, 2009, 10:00:02 am
Tag-Along
  • 25
« Reply #25 on: December 03, 2009, 10:00:02 am »
Thanks a ton guys! I am really getting some good info here.
I received my car as a shell, nearly bare bone. The only thing left on the car was the suspension, brake system, and windows.  But I was given a bunch of parts that came off of the car when I picked it up.  I was told it has manual steering, so I may have the correct column...in one of my boxes SOMEWHERE  :D
« Last Edit: December 03, 2009, 10:10:00 am by Tag-Along »
