Author Topic: Will a Golf 1.8T exhaust manifold fit 1.6N/A head.  (Read 4019 times)
November 30, 2009, 11:24:18 am
Jcolussy
  • 9
« on: November 30, 2009, 11:24:18 am »
I found a Golf 1.8t exhaust manifold with turbo down pipe and intercooler with all the piping for 500.00.. Wondering if the manifold would be able to bolt up to a 1.6 n/a head?
Reply #1November 30, 2009, 11:46:25 am
Re: Will a Golf 1.8T exhaust manifold fit 1.6N/A head.
« Reply #1 on: November 30, 2009, 11:46:25 am »
I'm perdy sure it won't.
Reply #2November 30, 2009, 11:53:09 am
gtidiesel1.6
  • 72
« Reply #2 on: November 30, 2009, 11:53:09 am »
wont even come close to mounting
8v:
1.8t:
Reply #3November 30, 2009, 03:09:04 pm
Jcolussy
  • 9
« Reply #3 on: November 30, 2009, 03:09:04 pm »
Cool thanks for the reply could i get the 8v manifold and adapt it to a k03 turbo
Reply #4December 01, 2009, 02:34:01 am
gtidiesel1.6
  • 72
« Reply #4 on: December 01, 2009, 02:34:01 am »
I could be wrong but i believe some AAZ mk3's came with a ko3 and with a 8v manifold that had the matching flange
Reply #5December 01, 2009, 06:19:10 am
« Reply #5 on: December 01, 2009, 06:19:10 am »
You are correct but the K03 on the diesel is completely different from that on the gasser
Reply #6December 02, 2009, 11:14:13 pm
gtidiesel1.6
  • 72
« Reply #6 on: December 02, 2009, 11:14:13 pm »
I figured it would be a bit different.
Reply #7December 02, 2009, 11:28:44 pm
Jay
  • 157
    Derv power !
    • TONA Valet & Detailing
« Reply #7 on: December 02, 2009, 11:28:44 pm »
Shamelessly stolen from Golfgtiforum.co.uk  ;D I think they are all be for gasser engines though.
All the following turbos have the same installation dimensions and
thermodynamical performance. The differences are only in the actuator that
opens the turbine bypass valve:
K03-011 (5303 988 0011) 150 hp, 65 N actuator
K03-026 180 hp, 85 N actuator
K03-035 180 hp, 85 N actuator
K03-044 150 hp, 65 N actuator
K03-045 156 hp (Ibiza Cupra), 85 N actuator with 2 ports
K03-049 150 hp (Sharan/Alhambra), 65 N actuator
The 180 hp versions have an actuator with a higher opening force due to the
higher exhaust gas pressure (which is a consequence of the higher boost
pressure). Otherwise the valve would be pushed open by the exhaust gas
pressure.
The following turbos are a further development (since 2000) and have an
improved and slightly larger compressor while using the same turbine (still
with the same installation dimensions):
K03-052 180 hp, 85 N actuator
K03-053 150 hp, 85 N actuator
K03-058 150 hp/180 hp, 85 N actuator
See here for some more info:
http://www.seatcupra.net/forums/showthread.php?t=35228
KO3s turbo numbers:
KO3-052, 053 or 058 For k03s
If you look into the inlet, the ko3 has 12 fins, the ko3s has 8.
