Author Topic: difference between k03 and k14??  (Read 11997 times)
November 26, 2009, 05:33:51 pm
Dirtrag2
  • 298
« on: November 26, 2009, 05:33:51 pm »
other than the obvious... ::)
are the manifolds and oil return lines compatible from a stock aaz k03 to a k14?
thanks
...Darcy
'97 Jetta 1.9TD ( dirtrag2 )
'88 Fox Wagon ( projekt Dirtrag 3 )
Reply #1November 26, 2009, 06:08:44 pm
Henchman
  • 183
Re: difference between k03 and k14??
« Reply #1 on: November 26, 2009, 06:08:44 pm »
11?
Seriously though, I would like to know too.  5 bucks says GEE-BEE knows.
Ian
Reply #2November 26, 2009, 06:39:08 pm
Kantdrivefast
  • 196
« Reply #2 on: November 26, 2009, 06:39:08 pm »
11?
Ian
5 bucks says he doesnt know, but still manages to add a link to a parts supplier or manufacturer for no apparent reason.
Reply #3November 26, 2009, 07:54:32 pm
4wheeler
« Reply #3 on: November 26, 2009, 07:54:32 pm »
The inlet and outlet are slightly larger on the K14.
The oil line is also different.
Reply #4November 26, 2009, 10:10:23 pm
GEE-BEE
  • 1604
« Reply #4 on: November 26, 2009, 10:10:23 pm »
OOh that hurt's  :P
manifolds are different , I have both turbo's and manifolds
Return hose assys are different:
K03 has two bolt adapter on the hose assy for the Turbo
K14 has a female fitting  on the hose assy for the turbo
Both have Banjo fittings for the block return...
Gee-Bee
You both owe me money !
paypal to [email protected]
« Last Edit: November 26, 2009, 10:17:56 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #5November 26, 2009, 11:11:57 pm
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #5 on: November 26, 2009, 11:11:57 pm »
i have 2 k14's - one from an eco-diesel and one on my aaz - the one on the aaz has the triangular inlet flange and ko3/ko4 style outlet, and the eco-diesel one is like the t3/k24 style with trapezoidal inlet and swaure outlet. i havnt had them bot next to eachother, but i think the compressor sides are about the same. outlets from turbines appear same diameter (exducer diameter). but trust me that the one on the aaz is actually a k14 - it still has its little plaque and is quite readable.
'91 Golf Cabrio 1.9TD
Reply #6November 27, 2009, 02:52:37 pm
Dirtrag2
  • 298
« Reply #6 on: November 27, 2009, 02:52:37 pm »
if i understand correctly, the k14 will mate to a T3 style manifold and exhaust but will need a modded oil return.?? right?
...Darcy
Reply #7November 27, 2009, 04:35:45 pm
Syncroincity
  • 727
« Reply #7 on: November 27, 2009, 04:35:45 pm »
11?
Ian
 :D :D :D :D Nice one...
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #8November 27, 2009, 10:58:47 pm
gldgti
  • 488
« Reply #8 on: November 27, 2009, 10:58:47 pm »
I've had several K14s from AAZ engines and they ALL had the trapezoidal flange for the exhaust inlet and the square flange for the outlet.  Are you sure you don't have one k14 and one k03??  Sure sounds like it.  I need pictures or I don't believe you.   :P  Even if the plaque says it's a k14, if the exhaust inlet and outlet were the K03 style I'd still think someone swapped the plaque or compressor before believing that it was a k14...
thats fair i guess... i'll go get pic.
Reply #9November 29, 2009, 04:16:37 am
gldgti
  • 488
« Reply #9 on: November 29, 2009, 04:16:37 am »
ok, so here is the spot where i concede defeat :-)
i went to take a photo of hte plaque i was sure was on the turbo, (which is behind all my intercooler piping and still frggn hot from a long drive) and i start thinking "i'm on drugs, why do i think i have a k14?" so anyway i begin pulling hoses and pipes and without finding any plaque i've just realised i sure do have a K03. i think a long time ago i have got it all confused in my head because of the k14 thats been sitting on my workbench for a year or so now.
but, after lots of inspection, its clear to me that i have a k03. nothing about the turbo looks k14, apart from the fact its got KKK on the exhaust housing :-) the centure section is definately k03-esque.
so, for all those wanting to run 20+ psi on a 1.9 with the k03 - seems fine. been doing it for 40,000km now :-D
