Author Topic: O2O starter research  (Read 3694 times)
November 24, 2009, 11:32:29 pm
zagarus
  • 619
« on: November 24, 2009, 11:32:29 pm »
So i've been trying to find a certain starter thread on vortex that i know would solve this issue for me, but i cannot find it.  Problem is this:
I have a 1.9TD that I am building and mating to an O2O tranny (for the time being).   As I didn't know I kept my stock diesel flywheel and PP I ended up using the flywheel from my coupes 1.8l gasser engine.   OF course this is a different size so to my understanding a diesel starter will not fit.  So my question is what starter can I use for a 1.8l gasser flywheel that will be strong enough to turn over the diesel.
I really wish i could find the thread on vortex as it had starter part numbers listed and different power ratings.
Hope someone can help me out here.
Reply #1November 25, 2009, 04:56:49 am
Re: O2O starter research
« Reply #1 on: November 25, 2009, 04:56:49 am »
A diesel starter will work with a gas flywheel
Reply #2November 25, 2009, 07:54:12 am
« Reply #2 on: November 25, 2009, 07:54:12 am »
i have a 8v clutch and 16v pressure plate on my diesel with a gas flywheel. they are much lighter than stock diesel flywheels. and the 16v plate really grabs better than the stock piece. btw, these parts were all on a 92 gas jetta. just be sure to have a diesel starter on a diesel engine, they are something like 2.1 horsepower, while gas starters are like .6 hp.
Reply #3November 25, 2009, 10:15:14 pm
zagarus
  • 619
« Reply #3 on: November 25, 2009, 10:15:14 pm »
to my understanding i thought the gear on a diesel starter was different then a gas starter. Well thats good news because i still have my old diesel starter :D  thanks for the help guys, might fire this thing up sooner now
Reply #4November 26, 2009, 08:02:21 am
rodpaslow
  • 670
« Reply #4 on: November 26, 2009, 08:02:21 am »
Will a new 1.9 gear reducer starter from an automatic car work on 020 as well?  I thought i read that somewhere, I just forget where if the 1.6 starter doesn't do it.
Reply #5November 26, 2009, 12:59:54 pm
rodpaslow
  • 670
« Reply #5 on: November 26, 2009, 12:59:54 pm »
SR34X?
Reply #6November 26, 2009, 02:22:07 pm
« Reply #6 on: November 26, 2009, 02:22:07 pm »
Even the 1.6 starters have gear reducers in them. There are the old mk1 starters and the really early mk2 ones that have about a 4" diameter. Those ones are direct drive. When the diameter went to about 2.5" that is when they started using gear reduction.
Early automatic starters won't work in place of a manual tranny one because they spin backwards.
Reply #7November 27, 2009, 12:32:48 pm
Black Smokin' Diesel
  • 656
« Reply #7 on: November 27, 2009, 12:32:48 pm »
