Author Topic: BOV delete?  (Read 2784 times)
November 23, 2009, 11:29:24 am
54321chris
BOV delete?
« on: November 23, 2009, 11:29:24 am »
What's the best way to delete my BOV?  I tried searching but couldn't really find a how-to.  Or should I just shop for a different intake manifold?
Reply #1November 23, 2009, 01:24:09 pm
Op-Ivy
  • 513
Re: BOV delete?
« Reply #1 on: November 23, 2009, 01:24:09 pm »
Depends what you are trying to do.
If you are trying to stop it from preventing your boost pressure going above 8psi then all you have to do is unscrew the screw in the middle and put something inside. I used a screw. Theres a thread somewhere but I can't find it because the new search sucks. :(
If you are looking to remove it completely, there is a block off plate that you can buy. Just gets clamped on same way as the BOV.
Reply #2November 24, 2009, 10:18:24 am
Re: BOV delete?
« Reply #2 on: November 24, 2009, 10:18:24 am »
Or you can just block off the hose coming from it.  A chunk of broom handle fits in there perfectly...
Reply #3November 24, 2009, 04:04:13 pm
tindias
  • 56
Re: BOV delete?
« Reply #3 on: November 24, 2009, 04:04:13 pm »
Where can you buy the block off plate?
'87 16v Scirocco w/ direct port nitrous
'81 Supercharged 1.6 Diesel Caddie
http://www.youtube.com/watch?v=XSAcDXLiCCk
'01 TDI Golf (daily driver)
Reply #4November 24, 2009, 06:20:17 pm
Re: BOV delete?
« Reply #4 on: November 24, 2009, 06:20:17 pm »
http://www.vwdiesel.net/forum/index.php?topic=18289.0
On the car that is the way to go.
Off the car TIG weld or spool gun it shut:D
Reply #5November 25, 2009, 12:49:39 am
Op-Ivy
  • 513
Re: BOV delete?
« Reply #5 on: November 25, 2009, 12:49:39 am »
Ah it was Giles selling it. Who knew! :o
