S-PAutomotive.com
Author Topic: Anyone found a 100% bolt-on MTDI pump yet?  (Read 31308 times)
Reply #45January 10, 2010, 12:44:46 pm
subsonic
  • 1836
Re: Anyone found a 100% bolt-on MTDI pump yet?
« Reply #45 on: January 10, 2010, 12:44:46 pm »
That's what this forum is all about man!  Making it happen! ;)
Reply #46February 13, 2010, 12:32:37 pm
chiefdiesel
  • 31
« Reply #46 on: February 13, 2010, 12:32:37 pm »
The 12mm LT pump is a direct bolt on install.  It has the proper timing curves, camplate, ect; the LT's are larger displacement 4 cylinder engines.  and I have not noticed any low end fueling problems.
2 B4 Passats Ecodes/HID/pp764/rc2
'85 Jetta coupe 1.6 n/a
'80 Caddy 110 (afn) m-tdi/12mm Lt 2.8 ip/.216/fmic
Reply #47February 13, 2010, 05:49:05 pm
westyventures
  • 45
« Reply #47 on: February 13, 2010, 05:49:05 pm »
The LT pump does have a low smoke governor. You can read all about it in the Bosch yellow jacket book to understand how it pulls back fueling to limit smoke at lower rpms. I have modified several to supply more aggressive fueling below 2000 rpm (on the smaller TDIs), and it does make a difference. Unless you have spent as much time setting these up on a variety of different setups as I have, then we have nothing further to discuss.
Karl Mullendore
www.westyventures.com
Reply #48February 14, 2010, 02:05:09 am
MJF
  • 581
« Reply #48 on: February 14, 2010, 02:05:09 am »
So, with governor modded LT pump. Can I expect same horsepower than 12mm electric pump?
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #49February 15, 2010, 03:59:37 am
« Reply #49 on: February 15, 2010, 03:59:37 am »
in the tdi-m the governor it's not the only single point  the came plate the intal pression the lda,the dynamic advance...
Reply #50October 09, 2011, 06:32:16 pm
markdelevo
  • 30
Reply #51October 09, 2011, 07:00:16 pm
« Reply #51 on: October 09, 2011, 07:00:16 pm »
1500 bucks is prolly more than giles would charge to build an MTDI.. kinda defeating the purpose. it would be counter productive to buy that pump, rather than have giles build you one FOR YOUR ENGINE..
Reply #52October 09, 2011, 08:45:17 pm
markdelevo
  • 30
« Reply #52 on: October 09, 2011, 08:45:17 pm »
Giles price is: for a normal M-TDI pump is $1400 with your providing 2 pump cores(TDI pump and one AAZ pump for him
to combine the TDI pump with)  if you are looking for more power He will need to upgrade the parts inside the pump
to do this it's an extra $700.
Considering those price and the cores + parts u can almost buy 2 brand new mtdi pump from those guys.
I think we need some input about their perform .
« Last Edit: October 09, 2011, 09:30:14 pm by markdelevo »
Reply #53October 11, 2011, 10:28:41 am
« Reply #53 on: October 11, 2011, 10:28:41 am »
Giles = $2000 for Mtdi. thats Gilesified!!
Reply #54October 11, 2011, 02:52:56 pm
« Reply #54 on: October 11, 2011, 02:52:56 pm »
At $2000 you got money to burn, and better be putting that pump in to one hell of a car.
Giles said to me in an email that his normal M-TDI ($1400) will be within the numbers of the stock electronic pump. And the torque curve will be there too.
Reply #55October 12, 2011, 01:29:13 pm
« Reply #55 on: October 12, 2011, 01:29:13 pm »
but if you dont have an AAZ, and a TDI pump, then its closer to 2 G's
Reply #56October 12, 2011, 03:04:03 pm
markdelevo
  • 30
« Reply #56 on: October 12, 2011, 03:04:03 pm »
thats correct
Reply #57October 12, 2011, 07:21:08 pm
« Reply #57 on: October 12, 2011, 07:21:08 pm »
Josh (Powered by Spearco) and i were just talking about M-TDI pumps a few nights ago, and the price of the giles unit was discussed, along with the core charges associated with it..
if you have the cores, the giles pump is the way to go, hands down.
i still think its the way to go even without cores. its a giles pump for christ sake!
Reply #58October 12, 2011, 08:55:16 pm
markdelevo
  • 30
« Reply #58 on: October 12, 2011, 08:55:16 pm »
Actually price go up more then $2000 for Giles mtdi pump if you want more then regular mtdi pump in your specific needs for an extra $700 (internal modification) plus dont forget the shipping cost if you are in USA or other then Canada.
So for the special pump for the performance diesel engine AAZ IP and TDI IP cores +$1400+$700+shipping .
Nobody would say anything bad about his pumps but this kind of prices would kill the deal in this kind of economy. Or people would just go to the electronic way.
I still want to hear some feedback about this pump: http://www.advancedautomotion.com/product_info.php?cPath=49_118&products_id=109
Reply #59October 12, 2011, 11:34:49 pm
« Reply #59 on: October 12, 2011, 11:34:49 pm »
has giles played with a rover pump yet??
ebay uk.. rover pump $200-$300... ship directly to him to work his magic..
but honestly my non modded rover pump with gov mod.. well guess it is somewhat modded.. makes my tdi-m run like big gasser.. with tons more torque.. next spring ill get it to a dyno.  screw with the fuel screw then.. but as of right now.. im so very happy with my rover pump.. when/if it eats the bed ill send to giles for fix/mods..
IMO its 100% bolt on with gov mod..
S-PAutomotive.com
